4020 Series Specs
   / 4020 Series Specs #111
Post however you want Mike. There sure are alot of other posts that are much less worthwhile than you editing something. /forums/images/graemlins/wink.gif
   / 4020 Series Specs #112
After running my 4710, I'd like to see on the new 4x20 series, a light on the dash that shows the mfwd engaged, also a brighter light for the pto engage, you can hardly see it when the suns out. I think a big thing they missed is moving the fuel tank to the rear. FNH has those in the rear, and that would be really really nice. As far as a different parking brake, I'm all for that. The 4x10 knob is a pain to get to sometimes. </font><font color="blue" class="small">( )</font>
   / 4020 Series Specs
Minor update - the Deere site has been updated again - looks like the 4x20 options are back and are settling down. Some of the options prices may have dropped back a little - seems like there were a couple of price increases for a few weeks when these were first posted. Now they seem to be pretty much what they were on the 4000 Tens. I might have seen that wrong before.
I hadn't paid too much attention to all the e-options that were available before for the old hydro versions so I can't say if anything changed there - but outside of that area it appears that all of the options that were available on the 4510-4710 are back except for draft control and the altenator upgrade, and the tire choices are a little more limited.
Unfortunately - no draft control so if this is the final list - then no Twenty series for me. /forums/images/graemlins/frown.gif
   / 4020 Series Specs #114
Well, I called Deere, never did that before. The Friendly rep got with an engineer, and...
Sorry, bud, "That is the one thing that was dropped in this model line. It was not engineered into it." No draft control.
   / 4020 Series Specs #115
Ok, I guess I'm still in line to learn new things. What is the difference between draft control and position control? I've seen this many times before and never got around to asking.
   / 4020 Series Specs
3 pt hitches these days are controlled in one of three fashions -
The simplest uses just a 'regular' hydraulic control valve and you move the valve one direction to move the hitch up - and the other to move it down, much like a loader. Some of the SCUTs or smallest CUTs use this approach.
Position Control is more sophisticated - basically - the 'normal' hydraulic control is buried inside the rockshaft system and connected to both your control lever and the hitch. Your control lever is set to a given position and the 3-point raises or lowers to meet that position. This is usually an 'active' arrangement - if there is any leakdown that lets the hitch lower - it should automatically cause the hydraulic fluid to flow and keep the hitch in one place. Position control keeps the hitch steady relative to the tractor and is needed for many rear implements - including rotary cutters, rakes, etc.,.
As far as I know, Draft Control actually predates position control on 3-pt hitches and is similar in that it is an 'active' system - but has an important difference. Instead of setting an absolute position relative to the tractor as with position control - you effectively set a draft load. That load should correspond nominally to a certain depth setting for a plow or cultivator. If the draft load lessens or grows - the hitch will move to try to get back to the same draft loading (not necessarily the same position relative to the tractor). The idea is that the implement will keep a steady pull (hopefully a steady depth) even if the tractor is running over slightly uneven terrain or the plow encounters an obstruction. Draft control is critical if you are going to do any significant plow/cultivation work.
While most current actual ag utility tractors (NH TNs, JD 5000's etc.,) include draft control standard, very few CUTs offer draft control (generally just the largest CUTs). FNH has it standard on the TC48/55 models. Deere used to offer it as an option to the 4510-4710 but appears to have dropped in with the 4000 Twenty series.
   / 4020 Series Specs #117
And the $50 question is "Why?"
Did it not work effectively?
Was it almost never ordered?
Are they pushing you up to the 5xxx?
Does the CNH version really work?
Is there a workaround?
bte, great description, tim!
   / 4020 Series Specs #118
I think that Deere may have underestimated the CUT market. On the bigger tractors you don't see much draft control either. On alot of tractors it's an option. Most farms now use chisel plows. Very little actual plowing goes on anymore. I don't know anyone that uses a plow anymore for farming. Besides plowing you really don't need draft control.
I don't think that Deere realizes how many CUT people actually use a one or two bottom plow.
   / 4020 Series Specs
ALL current Deere 5000's (5x03, 5x05,and 5x20), 6000's (6x03, 6x15, and 6x20), 7000's (small and large chassis), 8000s and 9000's have position and draft control standard. (How draft control is implemented varies a bit as you get bigger and fancier).
New Holland (/Case) includes it standard in the TC48/55 (DX48/55) on up through all the TN's etc., but I don't think it is available smaller than the TC48.
Kubota offers it as an option on the L4300 , all the "Grand L's" (L3130-L5030), and all of the "M's".
AGCO/M-F has draft control optional on the 1428-1440 and standard on the 1445 and 1455 CUTs, and all the 400's.
Around here with small farms and even smaller fields, traditional plows are still used plenty.
At least for a small percentage of potential buyers, IMO Deere has dropped the ball in a major way. Unless my dealer pulls a 4610 or 4710 out of the hat - it's off to Case/NH I go. I don't need a 3500 lb lawn mower. /forums/images/graemlins/frown.gif
   / 4020 Series Specs #120
Thanks for the explanation! /forums/images/graemlins/cool.gif The draft control kind of confused me, though. It sounds like position control, but does it have some sort of down pressure to keep implements in the ground? Does position control have any sort of down pressure?
2014 International Derrick Digger Truck (A55973)
2014 International...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
