7018 Vs. 7018AC, Need Layman's translation please:
   / 7018 Vs. 7018AC, Need Layman's translation please: #61
The price doesn't sound that bad to me, but I've never paid to have this kind of work done before.
   / 7018 Vs. 7018AC, Need Layman's translation please: #62
If it is cast iron,,don't worry about proving yourself,,,best thing you can do on cast iron repair is stop it from leaking,,or stop hole up from rain getting in,,any thing that is stressed,will probably break,sooner or later and generally sooner.
General consensus is that it isn't Cast Iron, but most likely mild steel or cast steel.
As you can see from the photos, I can only get so much resolution and still be able to post them to the forum. Much larger or sharper and I exceed the 1 meg upload size limit.
For all of you who know what you're doing, I'm sure that seeing it in person and truly identifying what type of metal it is would be a no brainer. There's the 'eyeball' test, spark test, shave test, and several others that I've read about that could be done to know for sure.
If it IS cast iron, I'm in no way experienced enough to be able to competently try a repair and think it would last. I don't have the proper tools to heat and then control the cooling process to help increase my chances of success.
   / 7018 Vs. 7018AC, Need Layman's translation please: #65
I'll bet you a buffalo nickel it's not cast iron!;)
   / 7018 Vs. 7018AC, Need Layman's translation please: #66
ok...
   / 7018 Vs. 7018AC, Need Layman's translation please: #67
Whats a buff nickle worth,,I'd raise you bet just cause,,you don't know either:laughing:
   / 7018 Vs. 7018AC, Need Layman's translation please: #69
Lets bet than,,I ain't got no 40210 thing so,,will match with greens,,[got a good crop this year],,,promise I'll pay off:laughing:,,,you don't know from looking at those pictures what it is,,,thats an old hog,,could be even older plate whatever on it,,only a fool bets on an uncertain thing...:D
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
1980 Gleaner F2 with heads (A57024)
1980 Gleaner F2...
(APPROX 125) UNUSED TRAFFIC CONES (A57193)
(APPROX 125)...
2009 MOROOKA MST-2200 VD TRACKED FLATBED DUMPER (A52707)
2009 MOROOKA...
