7018 Vs. 7018AC, Need Layman's translation please:
   / 7018 Vs. 7018AC, Need Layman's translation please: #61
The price doesn't sound that bad to me, but I've never paid to have this kind of work done before.
   / 7018 Vs. 7018AC, Need Layman's translation please: #62
If it is cast iron,,don't worry about proving yourself,,,best thing you can do on cast iron repair is stop it from leaking,,or stop hole up from rain getting in,,any thing that is stressed,will probably break,sooner or later and generally sooner.
General consensus is that it isn't Cast Iron, but most likely mild steel or cast steel.
As you can see from the photos, I can only get so much resolution and still be able to post them to the forum. Much larger or sharper and I exceed the 1 meg upload size limit.
For all of you who know what you're doing, I'm sure that seeing it in person and truly identifying what type of metal it is would be a no brainer. There's the 'eyeball' test, spark test, shave test, and several others that I've read about that could be done to know for sure.
If it IS cast iron, I'm in no way experienced enough to be able to competently try a repair and think it would last. I don't have the proper tools to heat and then control the cooling process to help increase my chances of success.
   / 7018 Vs. 7018AC, Need Layman's translation please: #65
I'll bet you a buffalo nickel it's not cast iron!;)
   / 7018 Vs. 7018AC, Need Layman's translation please: #66
ok...
   / 7018 Vs. 7018AC, Need Layman's translation please: #67
Whats a buff nickle worth,,I'd raise you bet just cause,,you don't know either:laughing:
   / 7018 Vs. 7018AC, Need Layman's translation please: #69
Lets bet than,,I ain't got no 40210 thing so,,will match with greens,,[got a good crop this year],,,promise I'll pay off:laughing:,,,you don't know from looking at those pictures what it is,,,thats an old hog,,could be even older plate whatever on it,,only a fool bets on an uncertain thing...:D
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52707)
2020 CATERPILLAR...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2010 JLG E450AJ TELESCOPIC/SCISSORING MANLIFT (A52707)
2010 JLG E450AJ...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
17101 (A55851)
17101 (A55851)
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
