A few questions before I order a tooth bar...
   / A few questions before I order a tooth bar...
Post some pictures and commentary AFTER you operate 100 hours with the Tooth Bar, or sooner, if you have a Tooth Bar or bucket failure of some kind.
Such information is valuable.
100 hours ? That might be in 4-5 years !:)
I've put 45 hours on the loader in the 2.5 years since I bought it.
I'll have some comments after 2-3 hours though.
   / A few questions before I order a tooth bar... #13
Third in favor of Piranha, look at the tooth design and check other comments on TBN. I purchased 2 and they have performed better than expected for my needs.
Neil
   / A few questions before I order a tooth bar... #14
I have a bolt on tooth bar on a 27 horse machine. I keep it on 80% of the time at least. Mine is a Bobcat tooth bar and is well made and I have no complaints, but I would consider the Piranha if I were to do it again. I would not worry about damage for a second.
   / A few questions before I order a tooth bar... #15
I like "beauty shots" and so do lots of others. Post what you get here. I'd like to see it.
   / A few questions before I order a tooth bar... #16
Based on other threads, I ordered a Ratchet Rake. Haven't installed or used it yet and it may not be a good choice for boulders but just wanted to add it to the mix.
   / A few questions before I order a tooth bar... #17
Ratchet Rake is the best bucket attachment for brush removal. It is pretty good for grading, better than a Tooth Bar.
You cannot dig with a Ratchet Rake.
   / A few questions before I order a tooth bar... #18
How many inches does the Piranha bar extend beyond the original cutting edge ?
There is a LINK in Post #3 that will take you to over 100 Piranha Tooth Bar threads in the T-B-N archive.
   / A few questions before I order a tooth bar... #19
Yep, I guess Jeff9366 remark was pointed at my post. The picture was taken right after installation of my PTB and only one I had to show the OP what a PTB looks like.
Guess I will take a picture of it tomorrow, under a pile of dirt so, Jeff can get his panties un-wadded? GIVE ME A BREAK!
Sent from my iPad using TractorByNet
   / A few questions before I order a tooth bar... #20
I prefer a tooth bar because I like being able to take it off. I think he needs more or your money and an all day bill cost more than a 1 hour job. This is a 20 hp tractor not a 20 ton gravel loader. I would just weld them on no preheat or other crap required.
UNUSED FUTURE...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
Deere 50D (A60462)
Deere 50D (A60462)
Landhonor Skidsteer Portable Screener (A59814)
Landhonor...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
