Add a Double Pilot Check valve to Side Link Cylinder?
   / Add a Double Pilot Check valve to Side Link Cylinder? #1
kcoburn
Eastern Iowa
5240HSTC and B7610
I bought an hydraulic side link cylinder for my last tractor. Soon after I installed it, I abandoned it because it rapidly allowed my back blade to drop. I bought it through the tractor dealer and they replaced it for me. No change with the replacement. This seems to be a common problem, described as "cylinder creep". Some suggest using a double piloted check valve cylinder as the solution. Hate to buy another cylinder. I now have a newer tractor and it looks like the cylinder dimensions are fine for this tractor. Is it possible, practical, and cost effective to add a double piloted check valve to the cylinder I have?
   / Add a Double Pilot Check valve to Side Link Cylinder? #2
I have no idea off correct answer, but will be watching thread to see what kind of answers you get. I may want to do this in the future.
   / Add a Double Pilot Check valve to Side Link Cylinder? #3
The valves are typically used in combination with spool type directional control valves to ensure leak free positioning of the actuator.
The inlet flow is free while the outlet flow is blocked. Pressure in the inlet line opens the check valve and allows free outlet flow.
Fluid should be very clean.
Vickers - Double Pilot Check Valves, DPC1-10
This valve cost about $84. Is it worth it for your operation.
https://www.google.com/search?q=hyd...ONkAfEpYC4Cw&ved=0CAgQ_AUoAg&biw=1024&bih=479
http://www.surpluscenter.com/Hydrau...K-VALVE-1-2-NPT-25-GPM-3000-PSI-9-5606-50.axd
   / Add a Double Pilot Check valve to Side Link Cylinder? #4
In reality all you need for the side link is a single pilot operated check. This would prevent the cylinder from creeping while holding a load but does not trap pressure from thermal expansion or while bouncing down the road with a load hanging on the 3 point hitch.
this one example:3/8 NPT 8 GPM BRAND PC37C PILOT-OP CHECK VALVE
Possibly contact Iowa Fluid Power in Cedar rapids. They are a Sun Valve distributor and probably have something on the shelf. They would possibly have the fittings required to plumb this up also.
I would recommend pilot ratio between 3 :1 & 5:1
   / Add a Double Pilot Check valve to Side Link Cylinder? #5
Just out of curiosity, how fast does it drop? How far does the ram extend in 10 minutes? Just wondering is all. To me anything at 1/4" per hour or less is acceptable. Some people think that it should not move at all. Those people need to have the check valves I guess. Problem with check valves is that you may loose other capabilities if your control valves are equipped with the float function. All depends on what is important to the operator I guess.
And to answer your question, yes you can add a DPOCV. You do realize that it is not the cylinder leaking, but your control valve. If it is the cylinder, the check valve won't take care of the problem, but 99.9% of the time it is the control valve. ;)
   / Add a Double Pilot Check valve to Side Link Cylinder? #6
........... You do realize that it is not the cylinder leaking, but your control valve. If it is the cylinder, the check valve won't take care of the problem, but 99.9% of the time it is the control valve. ;)
Really?
If the side link cyl is extending when it is creeping?
Please educate me how you come up with valve problems at 99.9%
   / Add a Double Pilot Check valve to Side Link Cylinder? #7
Unplug the hoses and see if the cylinder moves. Of all of the cylinders that I have sold, 2 have been the problem. All others have been the valve.
   / Add a Double Pilot Check valve to Side Link Cylinder? #8
Good answer Brian. Surprised someone else hadn't mentioned that yet. :)
   / Add a Double Pilot Check valve to Side Link Cylinder? #9
If true that means 99.9% of the time a cylinder w/check valve should stop leak down.
I know installing top/tilt cylinders with check valves stopped the annoying leak down problem I was having.
I have had the check valve cylinders on there for 10+ years now. They never move. They stay where I put them.
   / Add a Double Pilot Check valve to Side Link Cylinder? #10
Really?
I was thinking the same thing.
Manufacturers have a leak down rate for their valves and the dealer should replace the valve if it is under warranty, and leaking down more than the leak down rate.
I am sure the cyl manufacturer also have a leak down rate for their cyl.
I would say that the cyls are more at fault as people replace a lot more seals or cyl than valves.
Either one can be checked for proper operation.
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
15200 (A56857)
15200 (A56857)
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
