Adding hydraulics to truck crane
   / Adding hydraulics to truck crane #1
davedj1
Jackson, NY
Kubota L2501
I have this truck crane that I built a few years back, it works ok but I would like to get a 12 v dc powerpack to lift and extend the crane.
Here is the crane
I would like to pick up one of these: Surplus Center - 12 VDC 1.3 GPM 2500 PSI SPX SA POWER PACK
If I get the power pack (doesn't have to be the one I linked to but similar), can I use a selector valve and two control valves while switching between circuits electronically? IE the diverter valve would be electronically activated. My concern with using electronic valves is I won't have smooth control of cylinders, I don't want an all or nothing scenario. I want to lift the boom and lower with precision and extend/retract the boom without anything traumatic going on.
Any help greatly appreciated as always.
dave
selector valve: Surplus Center - SAE 8 6 GPM DOUBLE SELECTOR VALVE 12 VDC P15544-2
control valve: Surplus Center - 1/4" BSPP 12 VDC HYDRAFORCE SV08-30 SELECTOR VALVE
   / Adding hydraulics to truck crane #2
I have a rd bale spike bed with an electric over hyd system similar to the one you mentioned. I can start/stop my bale spear fairly precisely but not exactly.
thanks guys
dave
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
