After I mow the field how can I collect the grass?
   / After I mow the field how can I collect the grass? #1
jcw74801
I mow about 2-3 acres of field several times per year with a rotary cutter. It is thick bermuda, other grasses and weeds. I see all this nice green vegetation just lying on the ground and would love to mix it with my neighbor's barn litter to make some awesome compost for the garden.
I am wondering what would be best for collecting the cut grass? I have a Mitsubishi 30hp 4x4 tractor with FEL.
I also need to prepare about an acre of sandy soil for planting grass seed and I have a gravel drive that needs maintained. A landscape rake would be handy. Would it be any good at dragging the cut grass into a pile?
What else could I use to collect cut grass?
thanks,
John
   / After I mow the field how can I collect the grass? #2
Since you have other plans for it anyway, a landscape would be a good idea.
My wife uses hers to rake cuttings like that into plies.
   / After I mow the field how can I collect the grass? #4
Well, my landscape rake won't rake a fallen layer of leaves. If there's a pile (roll) then it will drag it. The problem is that the tines are too far apart and the raking 'touch' is too heavy or too light.
   / After I mow the field how can I collect the grass? #5
I would look for an old side delivery rake sitting in the weeds on an old farm or on craigslist for cheap. Then pick up with pitch forks and put on a wagon or trailer. Did this for years on neigbors small farm that didnt have a baler.
   / After I mow the field how can I collect the grass? #6
One of the varieties of hay rakes should work well.
I have used a home built rake using pickup tines and mounted it on the three point on my little tractor. It does work but not well.:)
   / After I mow the field how can I collect the grass? #7
I use my landscape rake to collect my cuttings. Works fine for me. I might have to make a couple of trips, but it gets the job done.
Wedge
Thanks for the ideas. I will start with a LS rake since I can put it to use right away. I am surrounded by hay producers so there should be a few hay rakes lying around. :)
regards,
John
   / After I mow the field how can I collect the grass? #9
landscape rake it...
soundguy
   / After I mow the field how can I collect the grass? #10
I almost posted the same question today. I used my landscape rake to rake grass into large piles and then pitchforked it into the bed of my truck. The rake worked OK -- it got most but not all of the grass up, ripped up the grass in some sections where the ground was wet. Using the pitchfork gives a great deal of respect for the old-time farmers who had to do whole fields that way.
Lots of work that made me think there must be an easier way.
Option 1: What would happen if I didn't collect the clippings? We let the field grow all summer and just cut it down last week. Will the grass just grow back through the clippings?
Option 2: Would it help if I let the grass dry first and then raked it?
Thanks
dc
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
1761 (A58375)
1761 (A58375)
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
