After I mow the field how can I collect the grass?
   / After I mow the field how can I collect the grass? #1
jcw74801
I mow about 2-3 acres of field several times per year with a rotary cutter. It is thick bermuda, other grasses and weeds. I see all this nice green vegetation just lying on the ground and would love to mix it with my neighbor's barn litter to make some awesome compost for the garden.
I am wondering what would be best for collecting the cut grass? I have a Mitsubishi 30hp 4x4 tractor with FEL.
I also need to prepare about an acre of sandy soil for planting grass seed and I have a gravel drive that needs maintained. A landscape rake would be handy. Would it be any good at dragging the cut grass into a pile?
What else could I use to collect cut grass?
thanks,
John
   / After I mow the field how can I collect the grass? #2
Since you have other plans for it anyway, a landscape would be a good idea.
My wife uses hers to rake cuttings like that into plies.
   / After I mow the field how can I collect the grass? #4
Well, my landscape rake won't rake a fallen layer of leaves. If there's a pile (roll) then it will drag it. The problem is that the tines are too far apart and the raking 'touch' is too heavy or too light.
   / After I mow the field how can I collect the grass? #5
I would look for an old side delivery rake sitting in the weeds on an old farm or on craigslist for cheap. Then pick up with pitch forks and put on a wagon or trailer. Did this for years on neigbors small farm that didnt have a baler.
   / After I mow the field how can I collect the grass? #6
One of the varieties of hay rakes should work well.
I have used a home built rake using pickup tines and mounted it on the three point on my little tractor. It does work but not well.:)
   / After I mow the field how can I collect the grass? #7
I use my landscape rake to collect my cuttings. Works fine for me. I might have to make a couple of trips, but it gets the job done.
Wedge
Thanks for the ideas. I will start with a LS rake since I can put it to use right away. I am surrounded by hay producers so there should be a few hay rakes lying around. :)
regards,
John
   / After I mow the field how can I collect the grass? #9
landscape rake it...
soundguy
   / After I mow the field how can I collect the grass? #10
I almost posted the same question today. I used my landscape rake to rake grass into large piles and then pitchforked it into the bed of my truck. The rake worked OK -- it got most but not all of the grass up, ripped up the grass in some sections where the ground was wet. Using the pitchfork gives a great deal of respect for the old-time farmers who had to do whole fields that way.
Lots of work that made me think there must be an easier way.
Option 1: What would happen if I didn't collect the clippings? We let the field grow all summer and just cut it down last week. Will the grass just grow back through the clippings?
Option 2: Would it help if I let the grass dry first and then raked it?
Thanks
dc
1999 CHEVROLET C7500 UTILITY TRUCK (A59575)
1999 CHEVROLET...
Pickup Truck (A59230)
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
Case IH 496 Disk (A59814)
Case IH 496 Disk...
Unverferth 9250 Auger Wagon (A59814)
Unverferth 9250...
