All newbies, FAQ:
   / All newbies, FAQ: #11
Geeez ... ya'll are a little pissy ... was everyone born with the know it all ... never had your first tractor, never even turned the key on a tractor, have no idea about PTO, HP, HYD ... quess it should be against the law to ask a question on TBN ...
This would be the written equivalent of what happened to Serene Branson as she reported on the Grammy Awards a couple day ago.
   / All newbies, FAQ: #12
Can a moderator stick this at the top of the forum? Great FAQ by the way.
   / All newbies, FAQ: #13
Spectacular list! I resemble many of those questions!!!! :thumbsup:
   / All newbies, FAQ: #14
That is why almost every where you go on the internet, they have a FAQ...
What I see much more often is a "sticky" that asks a few simple questions and explains a few other items for noobs...
Such as:
Did you SEARCH before posting a question to see if the topic has already been discussed?
Or:
When posing a question be sure to use a succinct description of the nature of the query...rather than something like "I need help"
   / All newbies, FAQ: #15
I thought ray66 had a good idea myself, he has been more than helpful to me and my questions. Could save alot of time, and sounds pretty informative too me. :thumbsup:
   / All newbies, FAQ: #16
:laughing::laughing::laughing::laughing:
   / All newbies, FAQ: #17
I agree with you i have been around equiptment all my life but not everyone has. A trouble shooting guide at the top of the page might be pretty helpfull. Sometimes i see questions that are just so simple to that i can not believe everyone does not know or undestand. Then i end up having a question myself. This place is unique in that there are heavy equiptment operators,Diesel Mechinics (sp) Pro Welders,Woodsman, Farmers and guys that just want to mow the lawn.I have never seen a place like this there is alot of knowlege out there. And all worh hearing.An older teacher of mine once told us in Vo-tech school "Boys you can learn more by listening than talking try it you'll be suprised". I have never forgot that it is always been true.
   / All newbies, FAQ: #18
Hey members, a newbie owner here. For future reference, I just wanted you all to know that I started here, have read all the posts, have taken notes, and so long as I can find the emergency break on my new tractor when i get home, I will sincerely try not to repeat one of these questions in the near future:D That being said, I've purchased my first tractor this past weekend, a 1974 MF135, Perkins Diesel, Pwr Steering, Standard tranny. Tractor is in good shape except for a leaking steering gear which I hope to address shortly. Will probably need some help with that, but I'll search the boards for info first. Anyway, just wanted to say hello.
   / All newbies, FAQ:
Welcome. The "list" is meant for new owners of MF compact tractors, which is the majority of those whom regularly post in this forum. Most of it will not necessarily pertain to your 135. There are some older model tractor owners who should be able to help you though.
   / All newbies, FAQ: #20
This is awesome. Some additional I thought of (sorry if any are dupes):
1. Lifting heavy loads with your bucket can cause your tractor to flip. Be careful.
2. You need to balance the weight of the tractor at each end. If you have a load of gravel in the FEL, you'll need something heavy on the 3PH. And vice versa.
3. It's easiest to back up hills with a 4WD tractor.
3. If you get stuck, you can often push yourself out backwards by using the FEL.
4. Use plenty of throttle. You do more damage by lugging the engine than by working it.
5. Always let your tractor warm up before working it.
6. ROPS are of no value if your seatbelt isn't fastened.
7. Don't be shy about using grease.
8. To connect or disconnect hydraulic couplings, make sure you first shut off the tractor and work the valve lever back and forth to remove any pressure.
9. If a hydraulic component stops working, try disconnecting and reconnecting all the hydraulic quick connect fittings. Sometimes that's all it takes.
10. If you haven't done it before, go SLOW. If you have done it before and it's dangerous, go slow anyway.
Weld on excavator thumb EK1212 (A56438)
Weld on excavator...
METSO QUOTEC NORDTRACK S3.7 MOBILE SCREENER (A60429)
METSO QUOTEC...
Compressor (A55973)
Compressor (A55973)
1994 Chevy 2500 Pick Up (A59814)
1994 Chevy 2500...
EZ loader trailer (A56857)
EZ loader trailer...
Kubota RTV X900 (A53317)
Kubota RTV X900...
