Allis Chalmers wd 45 won't run.
   / Allis Chalmers wd 45 won't run. #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
I got a allis Chalmers wd45 with loader and 3-pt. I have the loader off and was using the tractor to plow my garden. Ran for about 5-6hrs with 2short brakes cause my a** was sore. Then hooked the tractor to a 6ft pull behind drag to cross drag my garden so I could level out the rows. About half way through is started running rough. I had finished up running it on half choke. Barely been able to keep it running while just moving it. Cleaned the tank, sediment Bulb, and line into carb. Still won't run trying to move it. Need halp asap to finish my garden. Will get pics soon
   / Allis Chalmers wd 45 won't run. #2
It sounds like it's starving for gas.
You are on the right track: clean tank, clean line, clean carb, fresh gas, clean sediment bowl.
Problem has been fixed thanks
   / Allis Chalmers wd 45 won't run. #4
Well??? What was the problem???
Sorry was in school. The gas was bad and the whole sediment balb was filled of junk. The gas was white. Not clear. There was 4gallons bad but i was able to run it in my Craftman garden tractor to mow and till
   / Allis Chalmers wd 45 won't run. #6
Thanks for explaining. It was a cliff hanger. :)
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2009 IC Corporation PB105 School Bus (A59230)
2009 IC...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2016 John Deer 5075E (A60462)
2016 John Deer...
