Allis Chalmers wd 45 won't run.
   / Allis Chalmers wd 45 won't run. #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
I got a allis Chalmers wd45 with loader and 3-pt. I have the loader off and was using the tractor to plow my garden. Ran for about 5-6hrs with 2short brakes cause my a** was sore. Then hooked the tractor to a 6ft pull behind drag to cross drag my garden so I could level out the rows. About half way through is started running rough. I had finished up running it on half choke. Barely been able to keep it running while just moving it. Cleaned the tank, sediment Bulb, and line into carb. Still won't run trying to move it. Need halp asap to finish my garden. Will get pics soon
   / Allis Chalmers wd 45 won't run. #2
It sounds like it's starving for gas.
You are on the right track: clean tank, clean line, clean carb, fresh gas, clean sediment bowl.
Problem has been fixed thanks
   / Allis Chalmers wd 45 won't run. #4
Well??? What was the problem???
Sorry was in school. The gas was bad and the whole sediment balb was filled of junk. The gas was white. Not clear. There was 4gallons bad but i was able to run it in my Craftman garden tractor to mow and till
   / Allis Chalmers wd 45 won't run. #6
Thanks for explaining. It was a cliff hanger. :)
1997 FREIGHTLINER WESTERN STAR DUMP TRUCK (A60430)
1997 FREIGHTLINER...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2018 F550 Bucket Truck (A56438)
2018 F550 Bucket...
2020 DRAGON ESP...
General Purpose Loader Bucket (A59228)
General Purpose...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
