Another Generator guestion
   / Another Generator guestion
Originally Posted by Egon
Uhh, made a mistake. Should have said bath.
Ahh. One of my most favorite places that I have never visited. :)
Is that a bath tub, Bath NC, or Bath ME?
   / Another Generator guestion #42
I have a Generac 6500 watt (8500 peak demand) construction generator that I used at our last place more than a few times. I think the longest was three days.
Noisy and a gas pig but it got the job done. In order to have enough circuits, I wired in a 10k transfer switch but we were careful with our loads. With oil heat, we had plenty of power for our well pump, lights, the microwave and our computers and TV because often as not, we lost power but not cable.
With the main being in our basement under our bedroom, I had to run wire the 70 foot length of the basement into the garage. When in use, I wheeled the gen set out into the weather (not that I liked it that way) and shut the garage door.
My wife could handle the startup and manual switch over but not moving the gen set.
Now, a man I used to work with had a nice setup. He bought a generator powered by a VW diesel and set it up in a prebuilt utility shed along with a 275 gallon oil tank. With the exhaust ducted to the outside, the shed contained the noise very well. The whole setup was contained and out of the elements.
While working for an electrical contractor awhile back, I helped install a few Generac self contained sets. I think the biggest was 25kw. They were all propane powered Onan engines and could be programmed to start and self test monthly. The automatic transfer was pretty smooth. Nice set ups if you have the money.
One other setup worthy of mention though I cannot recall the money involved was using a surplus gen set once owned by Verizon I think it was. Powered by a vertically mounted five cylinder Audi diesel engine, the unit might have been 3x3 or 4x4 foot square and eight foot tall give or take. Originally used in one of those substations, it was designed for minimal footprint.
I do not recall where the man picked it up or how much power it generated though I think it was substantial because he had set it up for his business.
   / Another Generator guestion #43
schmism;1534856 Sounds like a good alternative. Let us know how it does on fuel use.[/quote said:
With the brush cutter I burn about .75-1.0 gph the last time I really paid attention. I have the 17 HP engine. I assume the genset would burn the same gph. The engine runs at the same RPM with the brush cutter or genset attached.
Later,
Dan
More thoughts-
I have been looking hard at an Inverter type Generator to deal with running some of my sensitive electronic equipment. Most Inverter generators are also more fuel efficient due to the way they control the speed to match the load. But they are $800-$1000 more expensive... that will buy a lot of fuel. It was pointed out by my generator dealer that a $75-$150 Uninterpretable Power Supply will clean up the power for electronic equipment so I can save money and get the cheaper generator. Hmmm... more things/options to think about. Especially since I was considering a UPS for some of the electronics anyway.
   / Another Generator guestion #45
Doc Bob,
No problem with cold weather starts. During our power outage a few weeks ago it was -10c or 14f. It started up 2nd pull- (first pull - didn't have it turned on).
Lloyd
   / Another Generator guestion #46
Noisy and a gas pig but it got the job done."
I think I have the same unit about 4 years old with a Briggs Engine and have to agree about the noise and fuel consumption. I do like the removable fuel tank and the large diameter wheels for dragging it outside of the garage. If I leave the fuel supply turned to the on position it will typically start on the first pull. I believe the newer ones have a Generac Engine vs. the Briggs.
   / Another Generator guestion #47
Jim, a couple of thoughts that I have not seen here. How deep is your well? I have a 330 foot well and the 4 KW generator would not start it. I ended up with an 8 KW and it does OK. My 5 KW is marginal on starting the well.
You refrigerator will need to run more than a few hours a day. Mine typically run 50% of the time during normal usage. So figure on 12 hours a day. I put my generator away from the normal living area so I can barely hear it in the kitchen/family room. I can hear in the bedroom, but I don't run it after bedtime, so no problem. The Honda's are much quieter, so they would be a good choice.
Good luck.
Good point on depth of well taking more power to get all that water moving. My well is in the 175-200ft deep range and it only has a 1/3 hp motor on it. I have been looking at a 6500 watt generator.. so I should be all set. I tried to go with a smaller 3000 watt inverter type... but if the refrigerator/ well pump and a few lights are on at the same time... then that is over the limit, especially for startup.
Your refrigerator will need to run more than a few hours a day. Mine typically run 50% of the time during normal usage.
Mine is new and I have been monitoring it, runs about 30% of the time.. which helps. It is the startup current in the fridge that is killer, running current is not too bad.
I can hear in the bedroom, but I don't run it after bedtime, so no problem. The Honda's are much quieter, so they would be a good choice. Good luck.
I was looking at the Honda Inverter model, it is enclosed and has very low dB (59) rating, clean power, fuel efficient and is very tempting... just not the $3800 price tag. :eek:
   / Another Generator guestion #49
We run the important things in our house (water pump, furnace, lights, cable VOIP modem, wireless router :rolleyes:) on a Generac 4500XL. We bought in 1998 on what was day 5 of no power following an ice storm (took 5 more days for power to be restored). Seems like it was ~ $1,200 at the time, but we didn't have any other option. I've seen them for < $1,000 since.
This has been a great unit and has about 300 hours use (I keep a spreadsheet so I know when to do maintenance). Seems like it used about 4 gallons for 10-12 hours of use. Maybe a touch more, but it's pretty fuel efficient. It's also not all that noisy. A bit louder than one neighbor's Honda generator, but lots quieter than another neighbors Coleman unit.
We backfeed it through a 220 outlet in the garage, but do unplug our chest freezer and the hot tub.
I always add Stabil whenever we get gasoline, that way I don't have to worry about it going stale in the the generator, lawn mower, or whatever.
It would be hard (impossible) for me to justify the cost of one of those big units on a concrete pad, etc. We just don't lose our power all that often - and when we do, this unit is the perfect size.
Good luck.
   / Another Generator guestion #50
I bought this one back in 1998. It has the Generac engine on it and though it is a hard pull, it usually starts on the first pull if not the second.
Re: the well depth.
The deep well at my last place was about 275 feet with a half horse pump. Surviving a couple of lightning hits, the pump quit about a year ago at age 20. It was on a sunday morning and I was due to work so I called a friend who is in the business and we could not pull it so we called another who brought his pump puller. I never did measure it but anyway, we went to a 3/4hp pump.
With both the 1/2hp and the 3/4hp, you could hear the generator rev up a bit with a momentary dimming of the lights but it did not overload.
At that particular location, we would observe some dimming with the fridge or the pump coming on. It did not bother me enough to persue why. The generator dimming was about the same.
2018 Ford Explore AWD SUV (A59231)
2018 Ford Explore...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
