Any body built a knuckleboom loader
   / Any body built a knuckleboom loader
BHD, that is what I am looking for. I need some info as to the gearing of the swing, I'll have to do a little math Ouch!. but all those pictures really helps.
I had the ideal of using the backhoe for the swing. everything was there, I just needed to lighten the load. I like the design of the log loader trailers, but not the price tag. Building something similar to the log loader trailers is what I have in mind. The knuckle boom will be mounted on trailer, but it will be part of a firewood processor and used to load logs onto the processor. I have looked for Mechanic cranes, but just not any around here, or at least not anything I can rob parts off of.
The hub I broke on my small boom was actually off a jeep cherokee front hub. It would have probably lasted for years just lifting a short round, but the stress of a large log on the end of a 14ft boom was just to much for the bearings and it pulled them out of the hub.
   / Any body built a knuckleboom loader #12
You need to somehow use 2 thrust bearing spaced apart. A single hub has 2 bearings just a couple inches apart so the torque is multiplied much faster. If you built a column maybe 2' tall with tapered bearings on each end it would handle at least 6 times the torque (24" vs 4" spacing on the bearings). It's definitely do-able but will require some machine work more than likely. I had thought of this as well, and the pivot is definitely the highest hurdle in the project.
I would get like a 2-1/2" to 3" shaft and put a shoulder of some kind on it to rest on the top bearing, have the other end threaded to to preload the bottom bearing. Make a plate that fits nice and tight inside of whatever mast material you are using and, weld it to the end of the shaft that will go into the mast about a foot, then have another plate to weld to the bottom of the mast and to the shaft.
Sorry if this isn't clear, I am bad at explaining things but I can picture it in my head.
I also like the sprocket/chain idea. Get a large (like 12") sprocket and cut out square or round hole to fit on whatever mast you are using and drive with hydraulic motor. I would even consider mounting it below the pivot hub, though it doesn't matter much either way.
I have some shaft, about 3in dia I think. I remember dads old bigstick wood loader. The boom just swiveled on a solid shaft with a hole thru the middle. The hole was for the cable to run thru. I am not sure of the solid shaft size, but know it was probably 3in or larger. The boom turned by use of 2 hydraulic cylinders. There was a drum on the bottom of the boom which cable was wrapped around. The cyl would pull the cable and make the boom turn. We loaded some big logs with that loader. whitepines 4ft+ in dia and usually 12ft long. We also broke several of the turn cables. Later dad sold the bigstick and bought a kenimer loader. Boom mount was basicly the same, but the boom rotated with the use of a sprocket and chain. Broke a lot of #100 chains to. As I recall, neither of the loaders liked to rotate with a heavy load. I suspect that if i go the hydraulic motor and sprocket, I would probably look to do something similar as show in the link BHD provided. A double sprocket, and best i can count, looks to be 60 teeth on the bigger sprocket. Biggest sprocket on the surplus center site is 60tooth, #60 chain and only a single sprocket at that. Looking at the picture in the link, it appears to have two single sprockets spaced to accept a double chain, not a true double row sprocket. After looking at the pics, I think I have a plan to make the swivel. Got to check out some spare parts to see if what I have in mind will actually work so i wont comment on my plan. Maybe i will anyways. Someone might save me the trouble of trying what I am thinking
I think I can find a big truck rear axle. Cut the hubs off each side, but leave the axle tube long for trimming later. Weld the axle tubes together and run a big shaft thru the middle to connect the two hubs. I can use the flanges off the axles to weld to my large shaft. Connect my sprocket to the bottom hub and make the turning part down low. I can use the axle tube to weld in the frame and the hubs should turn freely. Mount knuckle boom to top hub. This should provide me with a top and bottom bearing support (4 bearings). Just dont know if I can make a sturdy enough mount to weld to the top hub that will hold the boom. I'll just have to go look at a truck axle before I am satisfied it might work.
   / Any body built a knuckleboom loader #14
Interesting, I have been thinking that a large truck rear differential (17000lb cap) would be a good start. What I am thinking is to cut off one axle tube and weld a plate to hold the lube in. I want to place it axle up and use a rim to support the boom. I am thinking a hydraulic motor could be used to drive the differential like a driveshaft but might have to use chain and sprocket to adjust speed. Have to play with spider gears to lock differential but seems doable. I have an old prentice g that the head is all cracked on and would like to lower it and make a boom trailer out of.
A 17000lb axle might do and is sort of what I have in mind. Actually, I am thinking road tractor rears. I dont think using just one hub will carry the weight of the boom and load fully extended. A 17000lb axle is only rated for 8500lbs per side. I dont know the math for figureing out the total leverage weight of a 3000lb log at the end of a 16ft boom. A lot of leverage on a couple of bearing spaced less than a ft apart. That is the reason i am considering using both hubs, one at each end of the support tower. I think if i cut the cap off the axle shaft and replace the axle with a large piece of solid shaft, and then figure out a way to attach the round shaft to the other axle/hub cap, I would have the support of the 4 hub bearings, two at top and two at the bottom of tower with the added rigidity of the solid shaft material running thru the support tower. Maybe overkill and might not work as I think it would.
   / Any body built a knuckleboom loader #16
There are a ton of atv log loaders on alibaba. They almost all look to use the same base design of a rotary actuator and some sort of slew/ring bearing. They must have a cheap source...
   / Any body built a knuckleboom loader #17
This looks like what mike h was describing. It's the wallenstein timber talon 95. They use a "fiber glide thrust bearing" between the inner rod and outer pipe.
http://www.embmfg.com/File.aspx?id=2fcf52b7-77fe-416b-bcdc-7d9ec50ca357&display=full
Thanks Mike, I see that the support shaft on that loader is 3in dia. Looking at the specs for the loader, it is only rated for 900lbs. Not big enough for what I need, but the drawings can be adapted and scaled up.
   / Any body built a knuckleboom loader #19
Do you plan on adding stabilizers?
I used to run 2 trucks with Prentice G & H model booms, like cbailey1956 mentioned, and those stabilizers saved my butt more than once.
Used to put a 2 foot 2x12 under each of the pads when the spring thaw softened everything up, or after a week of rain.
I think stabilizers would be a must have for a loader. Since i plan on mounting it on a trailered wood processor, I am considering stabilizers on each corner. My plans are to drive up to a pile of logs, use the loader to load the livedeck, and use a conveyor to carry away the splits. I have been gathering parts for a few years now and am about ready to start the actual build. Plans constantly changing as i find materials, I upsized the original plans a few times already, but now I think I have a final vision in mind and only time and money are standing in the way.
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
JLG 1255 Telehandler (A56438)
JLG 1255...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
