Front-End Loader any use for a Boom pole? after having a FEL.
   / any use for a Boom pole? after having a FEL. #42
I have a 3 pt. plate for my bobcat and 3 pt.boom which I got whit my 9N, it's very handy ...
In one of the picture I replace the pump for my water well , in the other two I am installing the main been for the floor .
   / any use for a Boom pole? after having a FEL. #43
Depends on what ya need to lift. The 3pt will lift more weight than the loader but not as high. The loader will lift higher but not as much weight. I made this for my bucket for picking up stuff.
M.D.
   / any use for a Boom pole? after having a FEL. #44
when dad had his 3130 with loader he i used rhw boom pole on the back to lift the spike harrow when we pulled it.
   / any use for a Boom pole? after having a FEL. #45
My most recent boom pole use was lifting the top for the welding table I'm building.
   / any use for a Boom pole? after having a FEL. #46
That's a project , when you start the table make pictures .
I wish you easy weldsssss
   / any use for a Boom pole? after having a FEL. #47
I used my boom pole to take my boxblade out of the back of my van. When I bought it it took four men to load it and I removed it myself with the boom pole. With tight quarters I could not have gotted it out with FEL and it was too heavy to remove manually by myself. Worked very slick.
Hillman:)
   / any use for a Boom pole? after having a FEL. #48
I've used a boom pole a couple times when I needed more lift than my loader could provide, .. though for light objects.. etc.
soundguy
   / any use for a Boom pole? after having a FEL. #49
I use my 3 point pole to lift trees after I cut them down. Makes it easier and faster to cut to fire wood length than working on the ground.
   / any use for a Boom pole? after having a FEL. #50
I use a choker chain hitched to the drawbar to pull and the boom pole with tongs to lift:
Works great.
-Jim
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
UNUSED IRMC HIGH END ELECTRIC MASSAGE CHAIR (A57193)
UNUSED IRMC HIGH...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
1422 (A57192)
1422 (A57192)
Ford Pickup NR (A50323)
Ford Pickup NR...
2017 Kubota M7-151 Premium MFWD Tractor (A55315)
2017 Kubota M7-151...
