At Home In The Woods
   / At Home In The Woods #1,711
eepete has it right.
Break the deck up and picture frame it. It takes a few more joists and some blocking but will save wasting that expensive decking. Sorry for the rough drawing but you'll get the idea. Actually it looks very good this way and eliminates those ugly butt joints
Any reason not to make the deck longer with an uncovered portion? Seems like the deck could easily go all the way to the end of the house.
The deck does go all the way to the end of the house. 17 feet of the deck will be covered by the screen porched and 12 feet will be uncovered.
Obed
Pete and walleyed,
That's a great idea. We'll be talking to the framer on Saturday about the porch and see what he has to say.
walleyed, The drawing helped a bunch to visualize it.
Thanks,
Obed
The brickies were going to brick the top of the retaining wall that sits below the back porch. However, we needed to get some details from the framer regarding how he was going to anchor the porch posts to the retaining wall. So the brickies worked on the last wall of the garage instead.
The wife decided that she didn't like where the can lights were located in the kitchen so we started moving two of them this evening. She also wants one more can light installed directly above the sink and wants a switch that turns only that light on/off. Near the sink, there is a 3 gang electrical box that was roughed in for an electrical outlet and two light switches. I re-routed the outlet to its own single gang box to make room for the wife's sink light switch in the 3 gang box. We are not finished moving and wiring the lights. I surprises me how long it takes to do such small tasks. I don't really have a problem hiring the electrician to make some of these changes but he has not shown much interest in coming out to do these small things. I don't mind doing electrical work. I just wish I had more time. Don't we all?
nails will work screws will probably last longer. What does your brick mason say about nailing into the mortar joints of freshly laid brick? there maybe a cureing time...
The brick mason didn't sound thrilled about having the J-channel for the soffits nailed into the brick mortar. He thought the bricks might get knocked loose. The brick mason did suggest drilling holes and using tapcons to screw in the J-channel.
Obed
   / At Home In The Woods #1,716
Obed,
that was my thought as well...nailing the J chanel will likely cause a few bricks to pop loose...no mason ( or tradesmen for that matter ) likes to come back and fix completed work that has been damaged. :mad: talking to him about thios before it is done can help to ease the pain if one or two are poped loose especially if the siders use the attachment methods that the mason suggests. The hard part will be getting the sider to agree to tapcon the J chanel, as it will take more time than a nail.
do you intend to have a sealant joint ( caulking ) between the brick and the windows?
   / At Home In The Woods #1,717
Experience here on the can lights: I put mine up in a room. Read the manu. install sheet. Ignored the suggested spacing, as I put bulbs in them and walked around the room with a waist high newspaper (reading it). All was well until we actually moved into the room and I raised the bulbs up. Oops. Now I have dark spots.
I know, nothing to do with sink lights, but just a thought. Hard to catch everything.
   / At Home In The Woods #1,718
Glad the drawing made some sense. I build any decks over 16' this way. Looks better in my opinion & gives a more custom look. Clients like them. Allows me to eat regularly and live indoors which is kinda nice.
Also you can run boards diagonally but its really not an option with correct deck because of the waste and the high cost of composite type material.
Your house looks great by the way. I have been following along since the start
... Your house looks great by the way. I have been following along since the start
Thanks walleyed. You've been kinda quiet.
The brick work is almost done. There are a few windows and doors that need roll lock installed. The last brick on the ends of each of the retaining walls need to be laid. Our brick supplier does not have any solid bricks for our type of brick so the workers will have to cut bricks at the top ends of the retaining walls to cover the brick holes at the end. If you look closely at the top row of brick on the end of the retaining walls, you can see bricks loosely sitting on their sides and see the the open holes. You might need to zoom in on the picture.
Tomorrow the brick workers will lay the block for the front porch. We are being very involved in the making sure the block for the front porch is laid in a way that will satisfy us. There will be rebar tying the block to the house foundation. I'm not certain we would have gotten rebar if we hadn't specified we wanted it.
I've instructed the wife to not pay the mason the last check until the property is cleaned up to her satisfaction. The property is a mess with all the wasted brick, etc. lying around.
CHALLENGER MT 525B TRACTOR (A58214)
CHALLENGER MT 525B...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
2015 John Deere 544K Articulated Wheel Loader (A55973)
2015 John Deere...
NEW 5/16x7ft G80 Chain Sling Double (A59000)
NEW 5/16x7ft G80...
2016 INTERNATIONAL DURASTAR 4400 (A58214)
2016 INTERNATIONAL...
