Tororider
You will be surprised how quickly the much gets used. We chipped up twenty yards plus and it was gone within a couple months. Especially if you use it for paths through your woods.
I'm now thinking about running the two water pipes and two 1" conduits for low voltage and electric. You guys raise some good points. If I run a conduit for future electrical, then if I never need power to the garden I will not have gone to the expense of running a 200 ft cable. Also, if I did have a problem with the electrical wire, I could pull out the old cable and run a new one without the major headache of digging another trench.Electric and low voltage sound like great ideas. I asked the grading contractor to give me an estimate for running two 1" PVC water lines, a 1" conduit for potential low voltage, and an underground rated power cable. I just need to decide whether to put a 10/2 (120V) or 10/3 (240V) cable. A 10 AWG cable should give me about 15 Amps for a 220 foot cable based on the online cable size calculators. I need to check out how much 220 ft of wire will cost. I imagine we may need an electric fence around the garden to keep the deer out.
Thanks for the input,
Obed
On your PVC gutter drain pipes with clean-outs, you might want to think about spray painted them to reduce the visual impact. I did that with mine. Put a big piece of cardboard to protect the house and spray the pipe with some color that is close to the background color of the house/brick (cement in my case).
The first pix is a close-up. The gravel settled a bit so you can see the difference between the natural white PVC and the painted on this background. Second pix is a "normal people view" and not having that white blob of pipe there helps a lot.
It looks marginal close up, but from "normal" viewing distance it makes quite a difference. And I suppose if you really hated it, you could spray paint it back to white :laughing:.
Pete
Pete
Pete,eepete said:On your PVC gutter drain pipes with clean-outs, you might want to think about spray painted them to reduce the visual impact.
Pete
Must be an echo? How many TBN'ers does it take until it's a Good Idea? :laughing:
Answer: A Bunch.
Why Dave I merely took your great idea and reenforced it with some picture. Great minds think alike! (and fools seldom differ) :laughing:.
Yeah, the downspout is off a bit. A thread on the construction of this house would rival Obed's. I had the pipes in the ground, and the gutter guy had to try to hit them. Of course, the one he was off the most on (and the 1st one he did) was here by the front entrance. Why do the trades always start in areas where errors are the most noticeable? Typical "worth the battle or just move on" situation. BTW, the initial response from the gutter guy was "If you had just put in horizontal slat siding you'd never see it".
Just in that picture along there are epic tales of battles regarding the steps, the windows over the steps are not centered correctly in the space, the trim on the window, the gutter, getting the grade on the slab right, if we could have gavel fill between the slab and the house, the gray column to the right of the stairs (foundation issues), the pre-painted Hardie plank problems and the hand rail by the steps (do we need one?).
Anyway, as you can see in the enclosed picture the gutter gets "lost in the sauce" of the big picture so it's OK. The front entry area/steps are a bit dark in this pix, but you get the feel for it all.
Any finished house is a compilation of compromises because the project got done. But it's _your_ compilation and as long as the big picture is intact it's OK.
Pete
I can attest to that. Our front porch foundation footers are not square. I can't tell you how many hours my wife and I spent trying to figure out how to lay out the concrete blocks and brick around the front porch in a way that would not draw attention to the issue.dcyrilc said:...and I agree with you about the trades. They always seem to work out their construction issues in the most conspicuase place they can find.:confused2::laughing:
Ain't that the truth - very few seem to care...I have always performed my job/duties in a manor I would want someone else to use if I were paying for the final product out of my own pocket. I am continously amazed at how few people seem to share this commitment to the details of their work.
I hadn't thought about using the chips for paths and muddy spots but those ideas sound like great uses. Our path from the driveway/parking pad to the front door is red clay so we ask guests to come in through the garage. A path of wood chips might work until we have a permanent solution. As a final solution, we've considered putting some kind of pavers as a path to the front door but haven't definitely decided. With the ideas you guys are mentioning, I almost wish I had another mountain of wood chips. I haven't actually gone out and closely inspected the texture of the wood chips but from several feet away they chips look pretty fine, not like the wood chips that normally come to my mind. I believe that texture of our wood chips is fine enough that it will eventually turn into mulch that will be a great source of organic material for gardening.
Obed
A year ago we tried to get people to look at our logs and nobody was interested. We couldn't give them away. The logs are mostly white and red oak with some maple and poplar. The logs are 20' long with the median diameter = 18".I'm curious as to why you didn't sell the logs by the trailer load instead of paying to turn them into chips? Is there no market for log lengths where you are?
Alternatively you could split up and sell firewood to local people by hiring a kid to split your logs until done, yes?:
We havent built a fire since the fireplace guy left. Outside temps are in the low to mid 90s.What's the outcome of your fireplace test?
Covering the roots of the tree with dirt will kill the tree.Why are you not wanting the roots to your mature trees covered with topsoil? I can see why you wouldn't want the base of the trunk covered, but the roots?!:confused2:
