B2320, B2620, and B2920
   / B2320, B2620, and B2920 #31
thanks for the points Bandit and Chuck, I had it in my gut that the BH70X may be a little too big for the new B's, but man I wish the BH65 would swing 180, want the cake and everthing else. I'll need to talk to the dealer, didn't know about the extra weight needed in the front. I slightly view the extra tractor weight and size of the 2630 slightly negatively as more compaction for the lawn/yard, ruts, harder to maneuver, etc. From below, the 2630 is $600 more than the 2920, so yeah I have some thinking to do...
w/ FEL, hot-plug, loaded tires, hook:
B2620: $15,200
B2920: $15,800
B2630: $16,400 (last fall's price though)
B3030: $17,600
so Bandit $1800 more gets you the 3030...
javascript:void window.open('/WorkArea/showcontent.aspx?id=14621','showcontent','toolbar=0,location=0,directories=0,status=0,menubar=0,scrollbars=1,resizable=1,width=700,height=600')
Hopefully, this is a shortcut to the manual for the mounting of a Bh70x on a B7xxx series. On page 7, you will see the front weights I was talking about. They do a good job of balancing the tractor, but look awkward to remove alone.
Hmm, that didn't work, let's try this:
Well, I'm not having much luck getting a picture from a pdf file attached here....
   / B2320, B2620, and B2920 #34
Nice pics, HST is toe and heel...
PTO Specs:
noticed that the B20s for the PTO spec mentions 'Transmission driven with one way clutch' while the B30s mentions 'Independent'. What is the difference?
I'm sure that is a misprint. The "transmission driven" applies to the 2320 with the gear transmission.
   / B2320, B2620, and B2920 #36
If the difference is only $1800, I think I'd be choosing the 3030 over the 2920. Sounds like a good deal for a bigger FEL bucket, higher FEL capacity & higher reach, higher 3pt capacity, more hp, more torque, the far superior live independent PTO & position control. And if that's the case, it sounds like the B2920 is the same price as the B7800. Another $500 gets me the fender mounted FEL joystick on the bigger machines. Guess I'll have to put up with a separate seat for the backhoe.
It'll be interesting to see the numbers from the dealers I've contacted. I'm really surprised at such a small price difference between the 2920 & 3030.
   / B2320, B2620, and B2920 #38
photos seen here courtesy of Emerich sales in case you cyuld not tell from the stickers
   / B2320, B2620, and B2920 #39
B2620: $15,200
B2920: $15,800
B3030: $17,600
Any idea on MMM costs vs 26/3030
It looks like the drive over 54", and 60" decks for the B20 series will be less expensive than the existing decks for the B 30 series. Early price info that I have seen puts the new 60" deck at around $2200 msrp. I think the 60" for the B30 series is around $2500+ but don't quote me on that.
I don't think the front weights are required when mounting a BH70x on the B30 series, though I have seen B7800's with two of the plate shaped weights. ( The B7xxx requires 8 weights)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
68"X17' DOUBLE AXLE TRAILER (A58375)
68"X17' DOUBLE...
2009 Ford Econoline Wagon Van, 101,671 Miles (A56438)
2009 Ford...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2015 Case IH 180 Magnum (A57148)
2015 Case IH 180...
