B2320, B2620, and B2920
   / B2320, B2620, and B2920
It is pretty easy to get used to the two small pedals for the hydro. The only time I had a problem was when I got back on my riding mower that has the two pedals side by side. I'm not a big fan of having the brakes on the same side as the hydro pedal, but it works. I found a few times I was in a position where I wanted to hold the tractor in position with the hydro while I set the parking brake, and found that difficult. It is easier on the B series than on my older BX.
Often we are doing things behind us on the tractor, and if you turn sideways in the seat, or are looking over your shoulder to monitor what is going on back there, you will find the hydro pedal set up on the B's to be very nice! Make sure you try it in the positions you would be in when actually doing things.
The JD 2320 is very similar in size, and price, and does have the pedals side by side, and the brakes on the other side if you find you prefer that.
The prices I'm hearing on the Kubota 2320 are higher than JD's prices around here, and the msrp for the backhoe is higher than it is for larger ones. (about $7200 with a thumb) I hope that street prices are actually more reasonable once they get out there.
Anyway! It's good to hear that they are showing up here, and there. :)
   / B2320, B2620, and B2920 #52
Thanks Chuck. I spent some time going over the JD 2320 and 2520 when I go look at the 790, now 3005. I,we like them. There are some dollar differences between the two makers for sure. I was just asking what you guys see. Like the point you made about turning around. May not be a problem for someone say right handed but let a lefty climb up and might be a new set of problems. Even minor ones count at this point. :)
I liked being able to use that pedal with my heel when lining up the backhoe, or sometimes even using my left foot on the forward pedal when regulating a box blade, etc. Hard to do either with a transmission hump like the B30 series, or with twin pedals.
Though you can't try it in the showroom, make sure you try simultanious lift curl functions, etc. with the loaders on the tractors you are looking at. You will find a big difference in the valving on different tractors. It is nice to be able to "slice" a layer off the front of a pile sometimes...... like when turning compost, and you want to get what was outside on the inner part of the pile you are creating.
   / B2320, B2620, and B2920 #54
elalexander said:
Oh yeah, the dealer told me they had 0% for 3 years going on and most of his models qualify for it.
The 0% for 36 months is good on the older B's, but not the brand new B's, not the B7800, nor the deluxe B's (3030, 2630), where up until December, the 0/36 was good on all of the B's. Now the other B's are at 0/24, so not bad, but it should get better again.
Unless you are going with one of the B7x10's (which have 0% and should have very good clearance pricing), you should wait and see what Kubota does with the financing come April 1st - there will probably be 0%/36 on more models again, and the longer term rates and rates on new machines should be lower than it is now, since money is cheaper after the recent rate cuts. I would be surprised to see 0% on the new B2x20's, but it is possible, especially if sales really slow down this quarter.
   / B2320, B2620, and B2920 #55
Im thinking about jumping up to an L 3540 HSDC. I have 3.9 apr on my current loan with kubota credit corporation, i would hate to loose that rate!
   / B2320, B2620, and B2920 #56
I think you can lose that rate. My previous post was regarding the changes to the B series rates, and I just clarified a few points to avoid confusion.
You can get 0/36 on any Grand L.
Take a look at the following link...
Kubota Tractor Corporation - Promotional Rates
   / B2320, B2620, and B2920 #57
Thats a great rate, however, i would most likely go 48 months. Im going to have to pay off my existing note, add to that a new 3540 HSDC, fel & front blade, rear remotes & landpride rotary cutter! I think that payment over 36 months will be too rich for my blood?
   / B2320, B2620, and B2920 #58
That's why I'm waiting, because we should see a drop in all of Kubota's rates come April 1st.
   / B2320, B2620, and B2920 #59
Well I tried a B2920 today! Very pleased! I found my tractor. The engine is smooth running, not as loud as the 2630's, comfortable seat. The sales person hadn't tried it yet either until today, he was impressed, big competition to the JD 2320 was his words, big improvement to the 7610. Only odd design is in regards to the PTO. The selector for selecting Neutral, 540, or mid PTO is also the same lever to engage, i.e., no longer two levers. The clutch needs to be depressed to shift from Neutral, 540, or mid (2500). Also, when the mid is on, the rear is also on rotating at 960RPM, kind of strange for that speed. When the clutch is depressed the PTO stops. Since it is an HST, only time clutch is pressed is to select/engage PTO and to start the tractor.
   / B2320, B2620, and B2920 #60
Could you clarify this for me? Are you saying that if i have a pto powered impliment on the rear of the tractor, and engage, say a snowblower on the front pto......... the rear impliment will spin at 960?? I must be misunderstanding something here.
2020 DRAGON ESP...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
AEREATOR (A58214)
AEREATOR (A58214)
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2020 DRAGON ESP...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
