3-Point Hitch B3200 loud screaching noise
   / B3200 loud screaching noise #1
btrow
Indianapolis, In
Kubota B3200
Hi all. Purchased new B3200 and have 20 hours on it. After running garden tiller for approximately 30 minutes, the 3pt hitch quit lifting, and began making a very loud screaching noise when I pull on the lever. After letting the tractor sit for 10 or 15 minuites, everything works normal. When I would start working again, the no lifting, and screaching noise would repeat itself. Took it to the Dealer and they cannot repeat the problem. I suspect this issue will come up again so I will be prepard to video tape next time, but I am wondering if anyone else has had similar issues, and what the fix turned out to be.
Thanks!!
   / B3200 loud screaching noise #2
What's the status of the 3-pt valve knob under the seat by your feet?
Forgot to mention that. I had already fully closed, and opened the knob checking that first.
   / B3200 loud screaching noise #4
I'd do a little checking on your PTO shaft configuration. Could the angle be so steep you're generating heat in the Ujoints, then it starts screeching? Are the joints and shaft extension lubricated properly? Does the shaft extend freely and could it be binding when you try to lift it if it gets hot?
   / B3200 loud screaching noise #5
Good one but the three point stopping? Could the shafts be just a hair to long and putting pressure on the pto shaft going into the tractor?
   / B3200 loud screaching noise #6
Yes that's what I was trying to say, he sure doesn't want to damage that PTO stub or the seal.
   / B3200 loud screaching noise #7
I may be completely off base here, but I have also had a loud screeching from my B3200 with no 3-point lift when trying to lift an over full box blade (rippers hung up on roots). In my case I believe it was the relief valve. I backed off what was hanging the blade up and was able to lift.
I don't know what your exact situation is (never used a tiller) but have you got it full of material or engaged in the ground to the extent it is too 'heavy' to lift?
Just a thought......
Craig
   / B3200 loud screaching noise #8
Yes, definently check the length of the PTO shaft first. That could lead to a very expensive repair if it is too long.
If it isn't something physically stopping the lift from going up (such as the PTO shaft), then it could be the 3pt hitch valve is improperly adjusted. I'm not sure what all that entails, but in the service manual it says that squealing noise can be a result of an improperly adjusted valve. It could be that it is close enough to being in spec that it works normally most of the time, but when it gets hot (oil thin), it squeals.
Thanks everyone for your thoughts. I was doing a bush hog job today and the problem repeated itself with the bush hog. So the problem occurs with both the tiller PTO shaft, as well as the bush hog pto shaft. I was able to get the cutter to lift. Basically, the screaching was lasting a couple of seconds, with no lift, and then the screaching noise would stop and the 3pt would lift. However, the screaching always occurs when the tractor is hot. I got it on video this time and will be showing it to the dealer, as well as bringing up your suggestions.
Thanks again!
   / B3200 loud screaching noise #10
Thanks again!
Does it do it if you move the 3ph lever all the way, not stopping at the 1/4 in stop?
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2020 CATERPILLAR 302.7D CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
