B7100 Restore Project Has Begun
   / B7100 Restore Project Has Begun #121
I like your cultivator/hiller, JT. Is that an as-bought, a modification, or a custom built attachment?
I notice that the B7100 runs hot and has a lot of black smoke when I run the mower on "high" pto, but when on "low" works great and goes forever. Runs about 210-220 degrees and no smoke. Cuts through high wet grass like butter. The JD with a 709 on the back will cut through tree trunks but not as agile when in the woods grooming trails. Overall, it is a great tool and a good compliment to the big boy.
Thanks for the temps. That is what mine runs according to my gauge and is confirmed with the infrared. I hope to find a good used finish mower soon to use on some large areas that I mow with the Cub. I have really enjoyed using mine so far and looks like you have too.
Thanks, I took my cultivator and made a tool bar for it then bought the hillers and fabricated adjustable mounting plates. I keep the plows adjusted to take out the tire tracks and lay off my rows. The hillers can be turned up out of the way when laying off rows.
   / B7100 Restore Project Has Begun #124
Sometimes I just amuse myself:
...it does work great; but looks funny.
temps run 160-190 with this getup.
I have never gotten the HST temp gauge off peg - gauge works too; I tested it.
Good thing you put some weight on the front.
Got the rectifier on today and it is charging from 13v at idle to 16.5 at 3/4 throttle. Now I can pursue the headlights. Still haven't solved the high engine temp with PTO work but 6mmbr's B7100 is running in the same range using the PTO so I am wondering if this is normal for our tractors. If I could survey all B7100 owners who have installed temp gauges on their tractors then maybe I could get a good baseline for the correct operating temp. My Ford 1210 is also a 3 cylinder 16HP and it only runs 154 deg. using the same tiller. This is confirmed using my infrared on the head. The Ford uses a water pump with the same size radiator as the Kubota. I uploaded a video on youtube titled B7100 Dynamo Output but haven't found it yet.
   / B7100 Restore Project Has Begun #128
My B7100 Needs a engine , can anyone tell me what will fit in there besides a D750 and can I buy a engine out of a generator or something else that will bolt up ?
   / B7100 Restore Project Has Begun #129
If you don't get an answer here, try this other forum. I did a search and found this thread. According to posts its possible to use D750 or D850 or D950, and get more HP, and more options in finding something.
http://www.orangetractortalks.com/forums/showthread.php?t=6555
I also found a site diesel engine traders.
http://www.dieselenginetrader.com/engines.cfm?ID=44
Be mindful, there are some different setups regarding cooling systems, water pump or syphon. I think these vintage Kubotas used syphon.
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Champion Vibratory Roller (A60462)
Champion Vibratory...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
