Backhoe piston broke
/ Backhoe piston broke #1
seniornukect
2021 Massey Ferguson 1835M
Anyone run into this issue with a woods bh75? I am digging a trench for water and power lines and found a good sized rock. No way to lift it out so I dug a deeper hole behind it and when I went to push it back with the bucket I heard a bang and the dipper arm swung loose. Found the half of the eyelet in the hole, no sign of the grease fitting. It looks like really cheap pot metal.
/ Backhoe piston broke #2
Maybe a bad casting? Was this the first time you've used the backhoe? It looks like it can't have many hours on it. It's WAY too clean!!
First major job with it. Took down bushes and brush before.
/ Backhoe piston broke #4
Do you still have warranty? Otherwise a hydraulic or machine shop should be able to get it fixed.
/ Backhoe piston broke #5
At least it's an easy fix! It just didn't survive your first shake-down cruise with the new backhoe. First time you really stressed it.
I'll be surprised if Woods or your dealer doesn't just give you a new cylinder to pin on.
/ Backhoe piston broke #6
I'm a bit surprised on how thin the ring looks that broke. Would have expected something a bit more robust from Woods
/ Backhoe piston broke #7
Woods probably just buys the cheapest cylinders they can find.
Made in China!
/ Backhoe piston broke #8
Made in China!
In general I've observed woods to be better than a northern tool/harbor freight production. Perhaps that's changed.
/ Backhoe piston broke #9
I agree that the first step is to try and get woods to do a warranty replacement.
/ Backhoe piston broke #10
Replacement cylinder AND pin, for at least that side.
/ Backhoe piston broke #11
With all the manufacturing supply problems this year, there are too many variables to speculate. Your presumption is of course one of the many possibilities. :unsure:
Yup....
Could have also been manufactured in Bangladesh.
/ Backhoe piston broke #12
Certainly Woods does not manufacture their own hydraulic cylinders.
/ Backhoe piston broke #13
That would be my first call but it would probably be easier to just pay out of pocket and get back to work vs sitting around for 6 months hoping they fix it.
They will cover the warranty but the unknown is how it will take to get it. Woods doesn't have it, they are checking their manufacturer.
/ Backhoe piston broke #16
I was afraid of that. Warranty claims have historically taken forever. Combined with the recent materials shortages and labor shortages my expectations weren’t high.
/ Backhoe piston broke #17
Well, at least they're doing that. My dealer could only offer the full joystick rebuild kit that LS offered for $200+ instead of the individual ball joints I needed.
I did the legwork and found a source for the parts from the manufacturer's distributor and now my dealer is ordering spares from them to have in stock.
/ Backhoe piston broke #18
Anyone run into this issue with a woods bh75? I am digging a trench for water and power lines and found a good sized rock. No way to lift it out so I dug a deeper hole behind it and when I went to push it back with the bucket I heard a bang and the dipper arm swung loose. Found the half of the eyelet in the hole, no sign of the grease fitting. It looks like really cheap pot metal.View attachment 713444View attachment 713445
Im guessing the pin is bowing significantly and that boss sees extremely high stress from the bore trying to make the pin stay perfectly straight. Stresses would be highest with a new and tight bore - like yours. How wide spaced are the BH ears in comparison to the width of the cyl rod pin boss?
It's not tight, about 1/16th on either side. The pin looked fine, no issue removing it.
/ Backhoe piston broke #20
Clearly there was a defect in casting of the piston eye.
May have been made that way, or damaged at some point.
If you find can't get a replacement, it would suggest there is a known manufacturing problem.
Good luck with your repair.
Pick up Bed (A60352)
UNUSED RAYTREE RMDM70-70" HYD DISC MULCHER (A60432)
UNUSED RAYTREE...
2015 FREIGHTLINER CT114SD REFUSE TRUCK (A59904)
2015 FREIGHTLINER...
2017 CATERPILLAR 926M WHEEL LOADER (A60429)
2017 CATERPILLAR...
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
2003 McCormick XTX 185 XtraSpeed Tractor (A61307)
2003 McCormick XTX...
