BearCat Chipper/Shreader Any Good?
   / BearCat Chipper/Shreader Any Good?
The BearCAT I bought, the blade issue was a typical kid at
the counter failing to do his job. If I were to do this purchase
over I think I would look harder at getting the same w/ a
blower attachment. It piles debris and you have to shovel it
away or move the whole unit...Additionally you need to be
able to sharpen the 4 truck chipping blades and for that
I still need to either send mine out, or buy a makita 9820-2
machine. The shreadder blades should stay good for a
good long while. I would NOT use this machine w/ less than
17HP at the PTO as well.
   / BearCat Chipper/Shreader Any Good? #72
Art, Was thinking of buying a new sc5540b for 4700.00 what you think?
Murf I HIGHLY recomend you contact BearCat and tell them what you
have and what you plan on using it for and get an experts opinion...
I might call Kioti as well and get there's. Do not take my text as
gosple.
Having said that I believe that the DK40HST has 35.2 PTO H.P.
I believe the BearCAT SC5540B is a 5" unit, so the ECHO Bear Cat 5"
chippers and chipper/shredders require a tractor with PTO hp
ranging from 25hp to 45hp so that looks ok.
If you can afford it, a hydraulic feed would be VERY nice.
Make SURE it comes w/ a blower.
That BearCAT weighs 720 Lbs, Lift Capacity of tractor =, 24" aft of hitch, lb(kg) 2,493 lbs.
Make sure they give you a PTO Driveshaft w/ the deal.
Buy an extra set of chipper blades or price them first
and maybe ask for a set as part of the deal.
Buying used is OK so you may want to look for used too.
BearCAT builds a tough unit and from what I have seen
parts are not hard to get.
   / BearCat Chipper/Shreader Any Good? #74
Not even close to worth the money IMHO. For $5k, you're in the territory of a pretty nice power-feed chipper. The size of the opening into the chipper disc is very important and the Bearcat stuff is small.
   / BearCat Chipper/Shreader Any Good? #75
Well what do you suggest? Thanks for the reply.
What model do you suggest for him Brant?
   / BearCat Chipper/Shreader Any Good? #79
Nice move. Which Model did you choose and how much did you pay? I am considering the BX42S myself.
   / BearCat Chipper/Shreader Any Good? #80
I got bxm42 for 4,725 out the door. Seems everyone likes this brand the best. I could have got a Bearcat sc5540b for 4,625.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
