BearCat Chipper/Shreader Any Good?
   / BearCat Chipper/Shreader Any Good?
The BearCAT I bought, the blade issue was a typical kid at
the counter failing to do his job. If I were to do this purchase
over I think I would look harder at getting the same w/ a
blower attachment. It piles debris and you have to shovel it
away or move the whole unit...Additionally you need to be
able to sharpen the 4 truck chipping blades and for that
I still need to either send mine out, or buy a makita 9820-2
machine. The shreadder blades should stay good for a
good long while. I would NOT use this machine w/ less than
17HP at the PTO as well.
   / BearCat Chipper/Shreader Any Good? #72
Art, Was thinking of buying a new sc5540b for 4700.00 what you think?
Murf I HIGHLY recomend you contact BearCat and tell them what you
have and what you plan on using it for and get an experts opinion...
I might call Kioti as well and get there's. Do not take my text as
gosple.
Having said that I believe that the DK40HST has 35.2 PTO H.P.
I believe the BearCAT SC5540B is a 5" unit, so the ECHO Bear Cat 5"
chippers and chipper/shredders require a tractor with PTO hp
ranging from 25hp to 45hp so that looks ok.
If you can afford it, a hydraulic feed would be VERY nice.
Make SURE it comes w/ a blower.
That BearCAT weighs 720 Lbs, Lift Capacity of tractor =, 24" aft of hitch, lb(kg) 2,493 lbs.
Make sure they give you a PTO Driveshaft w/ the deal.
Buy an extra set of chipper blades or price them first
and maybe ask for a set as part of the deal.
Buying used is OK so you may want to look for used too.
BearCAT builds a tough unit and from what I have seen
parts are not hard to get.
   / BearCat Chipper/Shreader Any Good? #74
Not even close to worth the money IMHO. For $5k, you're in the territory of a pretty nice power-feed chipper. The size of the opening into the chipper disc is very important and the Bearcat stuff is small.
   / BearCat Chipper/Shreader Any Good? #75
Well what do you suggest? Thanks for the reply.
What model do you suggest for him Brant?
   / BearCat Chipper/Shreader Any Good? #79
Nice move. Which Model did you choose and how much did you pay? I am considering the BX42S myself.
   / BearCat Chipper/Shreader Any Good? #80
I got bxm42 for 4,725 out the door. Seems everyone likes this brand the best. I could have got a Bearcat sc5540b for 4,625.
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
Case IH 875 Disc Ripper (A59814)
Case IH 875 Disc...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
