john_bud said:Next time you bleed one, put the charger on while you do it. Will help keep the battery up.
Am expecting to see a post with "Vrrrroooom!" in it from you any minute now.
jb
john_bud said:The hammer treatment won't make it run better. Do try and avoid it!
When I get to your point, taking a break then starting from scratch and checking all the stuff from the ground up often finds the overlooked root cause.
Check timing, check for damaged gears, bent push rods, stuck valves, validate that you are on the compression stroke, etc.
jb
Iplayfarmer said:I've finally quit trying for the day. I had to stop before I threw a sledge hammer through the grill. I'm pretty frustrated.
I think I'm going to have to tear the whole front end out of the tractor in order to check and adjust the timing on the pump. (Hence the temptation to throw a hammer through the grill.)
I did adjust the valve clearances on the #2 cylinder. The intake was just under the requisite .014 in. and the exhaust was .021 in. The number one cylinder was all within spec.
I'm having a real hard time knowing when the injection pump is timed. I've got my wife turning the engine through the PTO with a crow bar and I can see when the bubble forms on the injection line, but I just can't see clearly enough to tell where 24 degrees is.
Sorry, I wish I had better news.
