Blackberries and Grapes
   / Blackberries and Grapes #21
Nice looking garden in the back of that picture, too.
   / Blackberries and Grapes #22
3 years ago I started a small orchard. I planted a bunch of apple, pear, and table grapes. Here's the layout I used:
main.php
Everything has grown well and this year I'm planting cheery, plum, and nectarine trees and a bunch of different wine grapes.
When we built the house in 2005, I told the wife I wanted to do something different with all the landscaping around the house. Everything we planted had to be edible or beneficial in some way. We now have blueberries, strawberries, and raspberries. We plant pumpkins, cucumbers, and a bunch of other stuff around the house. All the shade trees (so far anyway) have been sugar maples.
This year I may break the tradition and plant some roses.
Just for the sake of discussion while I'm waiting for the sun to come up so I can get started, how long would you all think landscape timbers would last for my application? I would expect that if I built my arbors or trellises or whatever they're called (does anyone have a more appropriate word than arbor, cause I can't think of one) out of untreated pine 2x4's that it would last at least 10 years before it rotted to the point of falling apart. I am guessing that my landscape timber model will last 20-30 years before it gets to the point that it has to be replaced. If I built it out of pressure treated 4x4's and 2x4's I would expect it to last 40+ years. My grandpa's got a grape arbor at his house that has been around as long as I can remember (I'm 31) and show's no signs of failing any time soon. I assume he built it out of pressure treated lumber.
So anyway, I believe that my landscape timber model will last as long as I want it to; meaning that I'll want them moved, modified, or removed before it fails due to rot.
And whatever the group consensus is, we should have a good baseline test started after today! Check back in 20 years for results!
   / Blackberries and Grapes #24
Shawn, maybe you know more about that lumber than I do, but I would think you are greatly over estimating the length of time the wood will last. I'd divide those estimates by 4.
   / Blackberries and Grapes #25
dooleysm,
I consider an arbor as something you can walk under which we have for some of our grapes and a trellis as a "wall" for support or climbing for vines.
So I think you are calling it the right thing.
Landscape timbers: I used them one time to build a dog lot. They lasted anywhere from 5 years to 15 years in the ground, some just lasted longer than the others. They only supported wire, with the grapes you will have added pressure from the vines and once you "cut back" or trim the vines you will be pulling them off the trellis or arbor, if you have a post that is rotting this pressure could break the post off.
Above ground they should last anywhere from 8 years to 15-20 years, just depends alot on climate factors in your area.
A treated 2x4 is not much different in price compared to the timber, but I would use treated 4x4 in the ground.
On some of our arbors we have galvanized pipe across the top wired together where they intersect. You can usually pick it up cheap at a salvage place. Just a thought:)
   / Blackberries and Grapes #26
I've used landscape timbers for fence posts and other uses. Around here they usually rot out in about 5 years. I've had 4x4 posts in for 20 years that are still good. The 4x4s have much more treatment than the landscape timbers.
   / Blackberries and Grapes #27
Come on over to western Oregon, you can have all the blackberries you want. You would have to look a long time to find someone who wouldn't be happy to let you take them all. They are kind of like the kudzu of the northwest.
It's hard to get rid of then damned things, so nothing you do to them will kill them except hitting them with Roundup in the fall.
When we built our previous house there was a small blackberry patch, maybe 10 ft. across in the front corner of our yard. The builder took them out with his backhoe, but he missed a few little pieces of cane, maybe 6 inches long. They got buried. I pulled out blackberries from that spot for 3 years, all growing from little canes. I don't dare eat any of the berries for fear we'll find them growing in the drainfield.
   / Blackberries and Grapes #28
In August, 1991, we had spent a week in Canon Beach, OR, then traveled a bit east and on August 18, 1991, we picked blackberries along the road near Brownsville, OR. As you say, there were plenty of them, and big pretty berries, too. Since we were living in a fifth-wheel, we didn't have room for too much, but we froze 2 ziploc bags of berries for cobblers, then made 4 pints of blackberry jelly, and I had 3/4 cup of juice left over that made pancake syrup.:D
   / Blackberries and Grapes #29
When I'm planning to put in a 4x4 or 6x6 pressure treated post in the ground, i will let it dry some and put a coat of tar on it.
Letting it dry out some will let the tar stick to the post better, and when i put the post in the ground with cement, i will let the cement come above the ground and slope it back towards the ground, so water won't stand around the post.
Well, the posts are in the ground, so only time will tell.
I've got loads of wild blackberry bushes, but they don't produce real well. The blackberries are tiny and there's not very many on each bush. We have to pick for an hour to get enough for a pie. The wild ones taste alot better, sweeter and smaller seeds, but they just aren't worth the effort.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
167 (A52708)
167 (A52708)
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
Deere 35G (A53317)
Deere 35G (A53317)
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
