Blew up Kubota motor
   / Blew up Kubota motor #181
Didn't u just need a block & a crank?? Unless those are deep scratches, it might be your only choice..
I must have missed it.. but what did EPS say??
They've never let ME down..
It might have taken them awhile to build me one but they always came thru..
I don't recall exactly what EPS said because I have called so many. But the consensus was since Kubota ag and Kubota industrial was different, and one had balance shafts and the other didn't, that I would need to go somewhere that handled the ag side.
To the matter at hand....yes I need a block. And yes this block "can" be rebuilt with a bore, hone, new oversized pistons and rings, I'd still need a new fuel camshaft since this non-turbo block is different, the lifter bores look questionable (I didn't post pics of them), and it would require using my cam and lifters.
I spent $2k on this block delivered, with the pretense that it needed no machine work. So $800-$1000 in bearings, re-ring, gaskets, etc. And I'd bw back in business for $3000 or so.
I was already looking at $3000-$4000 to rebuild MY block if it hadn't spun that bearing.
Now adding machine work, and new pistons, and the $2000 I paid.....I am back up to the cost of a new engine. So it isn't cost effective for me to want to mess with this.
Hope that clears it up. It's not about what can and can't be done. It's about smart use of money. I don't want to spend $6k or $7k for a rebuilt and oversized engine, re-using my whole top end and turbo.....when I can just buy a whole new engine for a little over $7k
   / Blew up Kubota motor #184
Dang ! I guess I'll scratch that place off my call list !
Are they going to take the motor back ?
What about all they told you about the motor, just a lie ?
Yea they are now on my black list.
Told me I was getting a mx5100 short block that needed no machining and was on fire.
What I got was a Mx4700?? non-turbo block....no evidence of fire....high hours and just flat wore out with lots of machining required.
Dont know if you can see it in the pics.....but it looks clear to me that they tried to hone the grooves out of the cylinders. There is NO cross hatch visible. Just radial lines like they honed but didnt move up and down. Trying to hide something.
Oh....and now they have my $2000. Funny how they get my money for two weeks, for a block I had possession of for 2 days. Wont credit me til they get the block (they lied to me about) back.
Sure would be nice to have that credited to my card before I call the dealer and drop $7500.
   / Blew up Kubota motor #186
I feel for ya, Bud..
Maybe that block was good enough for a "KY. rebuild"?? Lol
Now your stuck w/ reassembly AND return frt., that sux..
Good luck w/ your project.. stick it in the corner & maybe this winter/fall something will turn up..
Something "I do" when having to "store" a pump is> make a detailed parts list..
You never know when you'll get back to it & ya surely don't wanna have to sit down & go thru it piece by piece again..
   / Blew up Kubota motor #187
Man , sorry to hear this. I'll never call them again. I hope they credit your card back. You can always protest the charge.
You said they told you they had their mechanic check everything out ?
Perhaps they need to hire a real mechanic to check out their things instead of some hillbilly
   / Blew up Kubota motor #188
Sorry for your troubles LD...
I said in an earlier post that I was certain they were credible...
If they refund your money they are credible but misrepresented the engine...
Hope things work out for you...
Keep us updated...
   / Blew up Kubota motor #189
agreed, hoping they give you your $$ back - are they paying for the return shipping? I would certainly hope so.
   / Blew up Kubota motor #190
Sorry it was not what was represented.. makes me wonder if someone sent the wrong block.
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2018 Bobcat T590...
2021 Toyota Corolla LE Sedan (A50324)
2021 Toyota...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
Toro Workman HDX-D Utility Cart (A50322)
Toro Workman HDX-D...
