Bottom Plow ID and Questions
   / Bottom Plow ID and Questions #1
farmforwildlife
South Carolina
Attached are some pictures of a 3 bottom plow I located at an implement dealer that deals primarily in hay equipment. I'm looking for help in answering the following questions: 1. Plow is painted red but looks like a John Deere to me, I can even see what I believe to be the original green. Can someone ID this plow (make, model, year)? 2. Plow appears to be a trip shank plow, with coulters and trash covers, is this correct? 3. Handle to adjust angle appears to be missing, is this that big of a deal and can a replacement be found? 4. I'm not sure if it is a 3-14 or 3-16. I would be pulling w/ a 50 HP 2 WD New Holland. 3-16 seems to be pushing it a little bit but could I always drop one bottom and use the third for spare parts?
   / Bottom Plow ID and Questions #2
John Deere plow for sure. Measure from the inside of 1 beam to the outside of the next beam. Will be 12-14-16 inch. The handle may be hard to find, however, if you can lock it in place that plows the best (usually slot 3 or 4 from the front), that will probably the position your crossbeam will always stay in. I ran one just like it back in the seventies and I am thinking 145 series, but I may be wrong on that? Ken Sweet
Ken,
Thanks for the information. I suspect points and shins are still readily available for these plows. I read somewhere that they would be the "NU" series. So with all of your knowledge on plows, is dropping a bottom a feasible option if necessary due to HP limitations? I'm a little more interested in this plow just because it is close to home and I can get it for $450 which seems to be a good price.
   / Bottom Plow ID and Questions #4
That is a fair price with coulters. Points, shins, landslides and moldboards are available in this area. I am pretty sure the TSC type stores would also stock wear parts. Ken Sweet
Informational Lot - Shipping (A56438)
Informational Lot...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2005 JOHN DEERE 310SG BACKHOE (A60429)
2005 JOHN DEERE...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Freightliner Fuel Truck (A56438)
Freightliner Fuel...
