brake pads 2012 f-150
   / brake pads 2012 f-150 #41
I've also done brakes where it was just a disc in back. On some vehicles you have to spin the piston on the caliper to get it to retract to make room for the new pads. Its kind of a pain also but it beats the heck out of having to do two sets of brakes on the back.
   / brake pads 2012 f-150 #42
Superduty's have the little shoes inside the rotor hub. I have never had to replace them though.
   / brake pads 2012 f-150 #43
Ford had drums in the rear until the change to the Super Duty trucks in 99 when they went to a Sterling 10.5 axle with discs in they rear. they used a parking brake inside the disc. Dodge had a disc option in 01 but they didn't become standard til 03 and the change from the D80 to the AAM 1150. dodge also uses a brake inside the disc. chevy went to discs in 01 with the redesign. the only way i have seen them is with a caliper as the e brake as well
   / brake pads 2012 f-150 #44
Well no, they should last the lifetime of the truck since they don't actually wear.
The main problem I had with my Titan's e-brake was the brake lining was just glued to the shoes. They stuck to the inside of the drum and separated from the shoe. They really did not do a good job of holding the truck on a hill anyway despite several attempts at adjustment.
   / brake pads 2012 f-150 #45
Funny you mention that. Once, I had to park my 99 F250 with boat attached on a hill next to the cabin we rented. In neutral, it wouldn't hold still and I didn't want to just throw it into park and leave it. I found another less convenient place to park. I should've found something to chock the wheels.
When I apply the wife's mountaineer park brake that thing is rock solid. Same with my daughters little honda. I'm not impressed with F250's e-brakes as even my current 2007 is not "rock solid". It's not bad for just the truck but any trailer seems to overwhelm it.
   / brake pads 2012 f-150 #46
If you are not going to be towing a lot I would go with the Napa Adaptive one pads. They stop good and the pad life is good. If you are going to be towing a lot avoid ceramic pads. The Napa Reactive one rotors are nice but pricey.
Nobody machines brake discs these days as the cost of brake parts is cheap. I haven't used my brake lathe in years.
Fred
I agree, a brake lathe is a ting of the past. Most rotors are too thin to resurface.
   / brake pads 2012 f-150 #47
Yep, the ones I have done you back off the cable tension at either the e-brakes at lever or pedal in the cab with an adjustment screw or under the vehicle at the left/right divider.
You can't get at the hold downs, the lever assembly or anything without pulling the axles. All you can see of the e brake is the surface of the shoes, no way to access anything on the shoes...Mike
   / brake pads 2012 f-150 #48
I have NEVER had any issues with anything I got from autozone or advance. BUT I WILL avoid NAPA brakes like the plague. Everytime I have used them, the squeaking never stops. My 2001 saturn SL1 I put pads on about 3 years ago (55k miles). They still squeak and have since day 1.
Strange that you've had that problem. I've never used napa brakes, but my understanding is that they are rebranded wagners which have an excellent reputation. Well that is their "premium" line anyway, were you using their cheapest ones? In that case they are probably no better/ possibly worse than any other store brand.
I find napa's premium line of just about any product to be of pretty high quality. (Moog suspension parts, wagner brakes, wix filters...) The more I do, the more I am staying away from autozone, and find myself at napa more and more. More money yes, but just seems like better stuff. Actually I am spending more time on rockauto, where I know exactly what brand I am buying, but sometimes I just can't wait to have something shipped to me. I will go to autozone however for wheel bearings as they are usually timken.
   / brake pads 2012 f-150 #49
We too had issues with Napa brakes but with Rotors and Master Cylinders. Granted it was 15 years ago but have not been back since.
In my area Napa is not very good. The counter guys at Oriley blows them out of the water. Auto Zone and Advanced are on par with Napa but are 1/3 the cost.
Chris
   / brake pads 2012 f-150 #50
I always keep 2 sets of chocks and 4x4 wood blocks in the trailer.
   / brake pads 2012 f-150 #51
Normally, and I'm sure it varies by vehicle, there is a rubber plug that comes out and a star wheel you turn to back off the rear brakes shoes. It can be hard to find and hard to get at. My sons 2004 GTO had the drum brake inside the disc but didn't have the star wheel and traditional drum setup so it probably varies by make and year.
   / brake pads 2012 f-150 #52
My main complaint with the drum-in-rotor parking brake (it's *not* an emergency brake, btw ;) ) is that the backing plate is now a crappy piece of sheet metal, not a substantial piece of metal. I've had to replace the backing plates on my '06 F350 at about 50K miles - because the small parking brake shoes are still mounted to the backing plate. It is a plow truck so the salt takes its tool, but still - I've never had to replace backing plates that weren't mechanically damaged. And that's a pain, you do have to pull the axles and hub.
   / brake pads 2012 f-150 #53
Yep, only napa (silver line) I think have ever squeaked. Every brake/rotor job I have done and got parts from oriley, autozone, or advance....never an issue. And between my own, friends, and family, I have probably done 25-30 brake jobs in the last 10 years.
My reason for going with the cheapest pads, as I mentioned, has alot to do with just not wanting to wait any longer than that to get in there and take things appart. Make sure slides are greased, and give it a general once-over. cheap pads and cheap rotors are a good match. And seem to wear out pretty evenly. Since I can get ~60k miles on my cars (which are cheap to do anyway), I got no complaints.
As to NAPA gold being good stuff.....what I consider good stuff has to be taken case by case. While MOOG is typically good for suspension stuff, that is not the case with 03 and up dodge trucks. Especially the ball joints. Read any of the diesel or offroad truck forums and MOOG's on these trucks are to be avoided.
I guess what I am saying is, certain things I dont have a problem saving money and going cheap on. Sensors, brakes, light bulbs, coolant, etc. But things like bearings, filters, oil, etc I will but what I believe is the best.
   / brake pads 2012 f-150 #54
Napa brake parts are probably the best brake parts you can get at parts store for an OE replacement. A sqeuak on disk brakes is caused by a vibration. The pad should also be lubed everywhere it contacts the caliper. You should also lube behind the hardware on the caliper bracket to prevent it from rusting and causing the the pads to stick. Of coure the hardware gets lubed were the pad contacts it.
Napa claims they make their own brake pads. They have 20 some different pad formulations were their closest competitor has something like 12.
   / brake pads 2012 f-150 #55
Napa chasis parts are not made by Moog.
   / brake pads 2012 f-150 #56
I didnt say they were, someone else did.
Point of my post is: What may be top of the line brand in 1 application, may not be the best choice for others. Weather thats NAPA, MOOG, Wagner, Raybestos, etc.
While others may have good luck with napa brakes, I have not. (and remember I am dealing with the cheap lines). When it comes to them, I'll take Duralast (not gold) pads and rotors from autozone which would cost me $145 for the front of my truck vs Duralast gold @ $226. Heck, I could even spend $68 for HD pads and $192ea for a raybestos rotor. Bringing the total to $450+ for a front brake job.
I just cannot justify spending that as I wouldnt see a proportional amount service life.
Same for oriley. Pads ranging from $22 up to $75 a set. And rotors from $40 to $85
And same thing at advance.
Again, never had any issues with Duralast (standard line) or the cheaper wearevers from advance.
The rotors supposedly were OK. They turned them. I initially only intended to get the front ones done but my mechanic said the back ones needed done as well.
OK I have an update to this thread and a few questions.
So my initial brake job turned out to be a disaster. I paid my mechanic to fix the brakes but somebody messed up and installed them wrong. Apparently on the front brakes there is a certain way that the brakes are installed. Two brakes have a little set of ears on them and two do not. The ears go on the inside. They put both ears on one wheel and no ears on the other wheel, which caused the brake to jam/stick. I took the truck back 3 times and they could not find the problem. Finally I did a quick Google search and one of the first things that popped up was the little ears being wrong. I knew immediately when I jacked the truck up and the drivers wheel would not 'free' spin that I had a problem. I ended up buying new brake pads and rotors for the front and everything is good again. As for my mechanic I took the brakes to him and showed him how they were installed backwards and he seemed genuinely embarrassed and refunded my money. I have known this guy for 20+ years and he's always treated me right but I think he's got one too many grease monkeys working for him not paying attention.
Now as for the other problem. The brakes squeal really bad when I put the truck in reverse. It's mostly on a cold start but it will do it when it's warm too. My wife who has much better hearing than I says it's coming from the back wheels. I took apart the wheel/brake assembly and everything looks good. I had these brakes replaced also but not the rotors. My question is should I go ahead and replace the rear rotors and pads or should I have them turned again? Is there anything else I should try first?
   / brake pads 2012 f-150 #59
I'm at 35,000 miles on my 2012 F-150 and I'm wondering how you guys know it's time to change the brakes? I've always done my own with every vehicle that I've owned before. Reading this thread has been very informative.
Thanks,
Eddie
   / brake pads 2012 f-150 #60
There is a little metal tab that starts touching the rotor when there is about 1/16" or so of pad left. Makes a loud squeak so you know they are nearing the end of their life.
But I inspect mine frequently. Every oil change or so (bout 10k miles), I look at them. No need to remove them either. You can see the pad thickness through a little window in the back of the caliper
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
2015 VOLVO VNL760 SLEEPER (A59905)
2015 VOLVO VNL760...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
UNUSED IRANCH MINI EXCAVATOR RAKE (A60432)
UNUSED IRANCH MINI...
