Brillion Hub and Bearings
   / Brillion Hub and Bearings #31
Found another source for the felt washer. Now I just need to find time to put it back together.
What did the existing bearings look like?
   / Brillion Hub and Bearings #32
Brillion seeder - Nex-Tech Classifieds
Don't want to derail this thread but do have a question on this Brillion. I'm thinking that the 8' seeder could be cut in half and remaining good parts used to replace bad parts and a 3PT hitch added on. (Edit) To end up with a 4 ft 3PH seeder.
Could I get some opinions on the feasibility? I have access to fab and welding as needed.
Would it be capable of seeding K31 fescue at a rate of 5-10 lbs per 1000 sq.ft.? (215-430 lbs per acre)
I've only taken one apart so far as it was the only one that was easily identifiable as having a bad bearing.
Here's what it looked like when I opened it up.
   / Brillion Hub and Bearings #34
When they're bad, it's easy to see because they fall out in your hand like that.
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
NEW Fork Extensions (A59000)
NEW Fork...
1996 Isuzu NPR Box Truck, VIN # 4KLB4B1R8TJ000333 (A57453)
1996 Isuzu NPR Box...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
FORD TRUCK BED MAT (A52708)
FORD TRUCK BED MAT...
