Bucket Hitch
/ Bucket Hitch #1
sokoservices
virginia,virginia
Bobcat
Anyone have plans for a bucket hitch? Anyone used one before? Was wondering if they actually work and dont simply pull off of the bucket.
  • bucket hitch.pdf
/ Bucket Hitch #2
Whats a bucket hitch?
/ Bucket Hitch #4
I have one, with 2 clamp bolts, it wont stay put, slides side to side and works loose. I purchased a receiver housing from Northern Tool to weld on the top edge of my bucket. Its on my bucket list:laughing:
Dave
/ Bucket Hitch #5
I was thinking about getting one of those as one on the top of my bucket is too tall.
/ Bucket Hitch #6
I too have welded a receiver to the top of the bucket. It works great, although the bucket flexes a little when moving my larger trailers.
/ Bucket Hitch #7
See the attachement.
Ahhh there it is.. was looking at your post with my iphone and didn't see it.
Yeah looks like it would pull off... unless you drilled a hole in the bucket for a pin.
/ Bucket Hitch #8
It appears that there would be an issue with seeing the ball to easily hook up to the trailer. Maybe standing up would give a better sight line. I don't have that kind of set-up so don't know for sure.
Having a ball on the 3PH is very visible and no problem to get it lined up. The maneuverability is a bit less than with the ball on the front, of course.
/ Bucket Hitch #9
This is how mounted mine. I have a direct line of sight for hook ups.
/ Bucket Hitch #10
Has anyone simply drilled a hole in the center edge of the bucket for a ball? Different shank sizes are available, could go with as small a hole as 5/8" for a 2000lb trailer.
/ Bucket Hitch #11
I remember seeing a photo on TBN like that in the past. The problem would be seeing the ball for hookup. With my setup I can see the ball. Simply drive up to the the trailer lift and drive away. Works perfect and the receiver can be removed in a few seconds when needed.
/ Bucket Hitch #12
I welded a receiver to the rear of my boxblade and use a 2" and 2 5/8" hitch. works great, easy to see, lifts all my trailers without flexing and provides hook point for chains.
I have a toothbar on my bucket and there is not a good place to mount a ball there. If a hitch was mounted on top of the bucket, I could not get under one of my trailers, so I put it on the BB.
/ Bucket Hitch #13
I have one purchase from the same people that make Paynes forks. Works good but I also have a toothbar that helps to stiffen the bucket.
/ Bucket Hitch #14
I have a chain-on type receiver I got off ebay for cheap. Works great but seeing it requires standing up a bit. After reading this thread I wonder if I can attach it to the top of the loader...hmmmmm....
Caterpillar 330/330L Excavator Service and Parts Manuals (A63117)
Caterpillar...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
Cab Cam Monitor (A63117)
Cab Cam Monitor...
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
