BX 2200 LIFT ARM ADJUSTERS
   / BX 2200 LIFT ARM ADJUSTERS #41
I ordered the parts today...but they must be becoming "popular parts order items" as the prices have increased to $17.65 each. (At least at my dealer)
   / BX 2200 LIFT ARM ADJUSTERS #42
Ordered my parts online, tractorsmart, total inc. shipping $59.60. parts were here when i got home friday. will try to install this weekend and post pics.
   / BX 2200 LIFT ARM ADJUSTERS #43
got them on today, i think i'll like them
   / BX 2200 LIFT ARM ADJUSTERS #46
last shot, in this pic you can see that i placed a bushing in the end where the bolt goes through, the bolt is tight, yet the arm will pivot on the bolt
   / BX 2200 LIFT ARM ADJUSTERS #47
What size bolts, length and size did you use? I used the same pins that were on the tractor, on both ends of the bar and have a lot of side to side movement.
Thanks
Tom
   / BX 2200 LIFT ARM ADJUSTERS #48
Beautiful job, Milkman! I should have my parts this weekend when I return home from my business travel. I like the idea about the bushings and lock nuts.
   / BX 2200 LIFT ARM ADJUSTERS #49
OK I need some help here. I like the set up that Milkman used with the locking nuts. The size of the holes are different on the tractor plate vs. the bar. I was thinking of drilling out the tractor plate the same size as the bar, what ever that is?? and/ or drilling them both to a common size bolt?? And using a grade 5 or 8 ( higher the number the stronger??) bolt & washer and locking nut. Do you think this will work? Will drilling the hole bigger on the tractor plate weaken that part? Just need a little help here, just a little mechanically challenged (well maybe more then a little) when it comes to this tractor stuff!
Thanks
Tom
   / BX 2200 LIFT ARM ADJUSTERS #50
The difference in the size of the holes in the plate vs the bar is a good reason to use the bushing, I used a 1/2 inch bit to just clean up the hole in the bar, so the bushing would fit in, the bolts are 3/8 grade 5 fine thread bolts. I think they will be sufficient, if there is a problem, i can redo them to something heavier. Thanks for the feedback, keep up the suggestions, I love this site, it has a lot of good ideas.
2017 JOHN DEERE Z950M LOT NUMBER 86 (A53084)
2017 JOHN DEERE...
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
