I knew I was probably, in for a fun time today when I set out to mount my 60" MMM on the
BX25D for the first mowing of the season. My most clean, level place is my upper driveway landing of 3/4" stone. I turned the little wheels and pushed the deck under the tractor and of course, it dug into the stone quite nicely...even though the wheels were oriented for the task...okay. it's under...now to get the stupid thingys to come down to where they pin on and it seemed like they didn't want to come down...back inside to get the manual...says "set height knob to ZERO then lower arms..." Okay, didn't know that.
Go out and set the knob to "0" and the damned things still don't come down...I peek up under neath and move the down lever and I see they are coming down SLOWLY. Okay line the carrier up with the arms then go to work on the PTO shaft. About a half hour of grunting and yelling in pain as my ribs are pressed against the deck I finally get the shaft to click on...give a couple tugs and she seems connected. Yay.
Back to the arms and find the deck too sunken into the stone surface to allow the pins to slide into the carrier arms...so I set the pin to slide in and lift the deck and she snaps in! Go to the other side and repeat...lift, snap, good! Now to the front hangers and that is an easier proposition and then I'm done.
About an hour or so and Im ready to take off the backhoe and FEL...no big problems there...seems to be a cut and dry process, but remounting them after mowing and washing the BX turns out to be another pain due to the uneven and shifting surface of my driveway...I'll need to get a couple of sheets of plywood to set my FEL and BH on when I remove them...at least until my garage is built and my driveway is paved later this summer...Fun times! :confused2::mur:
By the way...the BX mowed beautifully! The only other little problem is the bouncy ride and bottoming out the seat springs with my 260 lbs...saw a thread somewhere that showed a modification of the seat springs...have to look that up.
