bx23 implements work on b2410?
   / bx23 implements work on b2410? #1
rtbme
i know the cat 1 implements w/work but how about the backhoe, undermount grass cutter, grass catcher, snowblower w/powerlift. I'm thinking not but you folks would know better than I. I'm considering a larger tractor. Dont like the thought of having to start over again gathering the implements.
   / bx23 implements work on b2410? #2
I'd advise against moving BH to a B from BX. The rest of the stuff, If you are good with metala fabricating, there is no limit if you are willing to revise and revise the changes needed until it works smoothly. Have you talked to a dealer to see what you might get for everything you have and get used implements for the B ? might be a better option.
Yes , I know w/fabracation I'd probably be able to get things to work but i'm not looking to get involve w/reinventing the wheel here. I've got enough projects in the shop. Would be awsome if the snow blower, 60" deck and grass system just mounted. I realy had my doubts, figured I'd inquire here first. Thanks for the input.
   / bx23 implements work on b2410? #4
I've read and heard that the BX23, BX24 and BX25 were specifically built to handle the BH (extra support on the frame). That's not to say that it couldn't be mounted to the B, but the frame may not be able to handle the extra force and then you run catastrphically damaging it. Couldn't see why the mower wouldn't work though (other than maybe slight modifications). Come to think of it, you may be spending more money on making the modifications to the B2410 to accomodate the attachments instead of starting from scratch.
   / bx23 implements work on b2410? #6
The backhoe, midmount mower, and grass catcher won't work without extensive modification. The snowblower will, but you will need a different quick hitch, and pto shaft. Look for old posts by Killer_B. He moved from a BX to a B, and moved some stuff with it.
   / bx23 implements work on b2410? #7
I was looking at a B when I found my BX23.
Wouldn't trade the BX23 for a B2410.
But would take one in addition to the BX23.
another BX brown ? 4 BX's on 2 acre lot brown ? you willing to deprive another man on earth from owning a kubota ? I'd be careful brown- getting 4 bx's will make each other jealous and they could start a riot! :p
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
Kubota RTV X900 (A53317)
Kubota RTV X900...
2003 Big Tex 10PI...
2016 ISUZU NPRXD 14' BOX TRUCK (A60430)
2016 ISUZU NPRXD...
