BX24 REVERSE
   / BX24 REVERSE #12
What you describe here, soundslike the normal HST whine.
I would agree. These units to whine alot. Seems like more with heat too. Fluid type really does not matter.
   / BX24 REVERSE
Is there something that would cause the reverse to not engage when I am on a
up-slope?
   / BX24 REVERSE #14
The whine may be normal but the lack of power seems to indicate a definate problem. I know my BX24 has no problem with a load going up a hill. There have been reports of HST failures on here. Hope its not that. When you changed the fluid did you change the filters ?? Clean the screen??
   / BX24 REVERSE
The problem appears to be mainly in reverse. On a flat surface it is fine. But if I back up an incline, no-go! Very frustrating.
   / BX24 REVERSE
The pressure in forward is 2700 psi
reverse 1200 psi
   / BX24 REVERSE #17
When backing up do you feel any pulsating or back pressure on the peddle? When you said metal to metal with hydo fluid between, are the brakes on, or maybe adjusted all the way up and no pad left ... and that is in the fluid blocking a port so I fear that it is something in the tranny.
   / BX24 REVERSE
I believe that your fears are correct. They are going to open it up to determine the cause.
ALLISON TRANSMISSION (A55745)
ALLISON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
