Can I tell you I love me new Hobart 210MVP welder
   / Can I tell you I love me new Hobart 210MVP welder #1
Cavjock22
Seabrook, TX
Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
Guys..
This welder is awesome. Building a stair case with it.. Mostly 3/16 thick material.. 10 min after unboxing and hooking up the gas.. She was off and running.. Used the recommendations for the wire speed and voltage and all was perfect. I値l post pics later..
$100 rebate gets the welder for $829.00 thru tractor supply
   / Can I tell you I love me new Hobart 210MVP welder #2
I've heard nothing but good about the MV210,congatulations and glad to hear you've put it to work. I'm doing ok with my Lincoln Pro 180 but patiently waiting for a good deal to show up for a used Ironman,,,,,,,then I will pounce.:pinkpanther:
   / Can I tell you I love me new Hobart 210MVP welder #3
Wish I had bought the 210MPV instead of my HH 140... But I didn't know at the time if I could even MIG weld decently and that my projects would get so BIG...
Dale
I strongly considered the Lincoln PM210 but couldn’t justify the upgrade.. I still have my 225 for rusty stick welding.. lol
Dale
Once you start Mig welding... You won’t touch anything else..
   / Can I tell you I love me new Hobart 210MVP welder #6
Congrats, its a great welder!
Love mine, and I really haven't used it to its full capacity. I've only run flux core and run it on 120V. But it does a great job and has "hot glued" everything I've need to stick together. I'm far from a welder, but a fair hot glue-er.
One thing that has been plaguing me lately is that the wire binds in the lead. I think a spool gun would really help. Or switch to gas and have pretty welds too.
I started out with 120V but switched to the 220 .. All on mig.. Once you start using grass, you won稚 go back to flux core.. I was surprised how well the recommended settings worked on the chart based on thickness. I have a lincoln handy mig and the recommended settings don稚 seem to work very well.. It welds very good but just have to monkey with the wire speed and amps. It痴 for sale.....
https://www.homedepot.com/p/Lincoln...Gas-Regulator-and-Hose-115V-K2185-1/100596739
I started out with 120V but switched to the 220 .. All on mig.. Once you start using gass, you won稚 go back to flux core.. I was surprised how well the recommended settings worked on the chart based on metal thickness. I have a lincoln handy mig and the recommended settings don稚 seem to work very well.. It welds very good but just have to monkey with the wire speed and amps.
It痴 for sale by the way..
   / Can I tell you I love me new Hobart 210MVP welder #8
I got a Hobart 210 MVP earlier this year. I run it with gas both on 120 and 220V. I was a proficient stick welder, but MIG is great. Done a lot of projects, and my welds have never been as good as they are now. It offers great flexibility in setting up for different thicknesses and configurations (tack vs full thickness welds). It is heavy, but it had the features I wanted. The current rebate makes it a great deal.
   / Can I tell you I love me new Hobart 210MVP welder #9
Another fan here. I only have used flux core and have been perfectly happy. The 110/220 connection has worked perfectly and I use the table inside the door for setup.
I picked up the el cheapo Harbor freight welding cart to place it on.
Had to cut a plywood "floor" to raise the welder up enough to open the side door to clear the lip of the cart.
I have a Lincoln tombstone that hasn't been plugged up since I got my 210 MVP.
   / Can I tell you I love me new Hobart 210MVP welder #10
I also have the 210MVP and it's been a champ for sure. Easily handles anything I can throw at it and never any issues. Getting ready to throw another 10lb spool of wire on it as we speak.
   / Can I tell you I love me new Hobart 210MVP welder #11
OK, I'm curious - Mark: what does Everlast have that's comparable?
   / Can I tell you I love me new Hobart 210MVP welder #12
For about $50-100 more you can get a PowerMTS211si. It's an inverter machine instead of transformer, has higher duty cycle and more amps, and comes equipped to do tig with HF start, and stick.
I've done a few welds with the one I recently bought. I'm far from expert but it's nicer to use than my old Lincoln.
   / Can I tell you I love me new Hobart 210MVP welder #13
My wife got me one for Christmas, I’d written off a Hobart mig because the price. There’s a local roofing company that buys them new every year and if they don’t use them they sell them at the end of the year for tax write off. So we got the 210 mvp for $700 new in the box. Can’t wait to fire it up!
   / Can I tell you I love me new Hobart 210MVP welder #14
My wife got me one for Christmas, I壇 written off a Hobart mig because the price. There痴 a local roofing company that buys them new every year and if they don稚 use them they sell them at the end of the year for tax write off. So we got the 210 mvp for $700 new in the box. Can稚 wait to fire it up!
Have questions about how to use it?
Forums - Weld Talk Message Boards
Dale
   / Can I tell you I love me new Hobart 210MVP welder #17
Once you start Mig welding... You won稚 touch anything else..
Sorry Can't agree with that, have had a 240v mig for over 30 years and while it is a great all around welder especially for steel 1/4 and under,
Once I got a a dc tig and then an AC/DC Tig/stick they all have their place
There are a couple repairs that I migged ( spindle repair on a riding mower that the spindles were no longer available,)
I would do my best cleaning and migging up the spindle blade mount always got about 1/2 season before the welds would break.
Decided to switch to TIG and it has been at least 3 years and no sign of failure. Just seems to have provided a better stronger weld.
Aluminum welding comes up from time to time and It is nice having a big dinosaur 300 amp tig that can weld up a broken casting when needed to an aluminum shovel, I did try the mig on aluminum and it works OK and is much faster so there is that.
Having the stick welders is nice to , just used stick weld up a broken ear on a cast iron engine block. If I need to weld a 1/2 inch implement using stick it can be done with plenty of power and heat.
Seem to be able to find a stick rod for most anything as well as tig rod.
I do agree for most quick repairs on steel that isn't to thick, Will grab the mig 1st.
Also- Congrats on the new 210 MVP Glad it is working great for you
   / Can I tell you I love me new Hobart 210MVP welder #18
Another vote for the 210 Hobart MVP. I don’t think I’ve used it on 110v but it’s a crazy solid 220v machine. I have it on a cart and it never leaves the shop so no need for an inverter machine.
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2844 (A58376)
2844 (A58376)
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2010 Case 580N (A60462)
2010 Case 580N...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
