Can one just build a bush hog?
   / Can one just build a bush hog? #1
andrewj
Platinum Member
South Carolina
JD 5105
I spent a little much on a JD lx6 that did not last long. almost everything on it is broke due to my abuse, and the hidden stumps/rocks in land I was unfamiliar with.
so, I can't see paying 2 grand for a 7 heavy duty foot cutter. Can I just buy plate steel 7 by 8 or so, brace it, add 3 pt attchment, tail wheel, and gearbox?
Anyone know how much just the deck would cost if made of 1/4 inch steel?
   / Can one just build a bush hog? #2
I saw a homemade one as a child. An older gentleman near my grandparents could build anything.
He had a 6' bushhog that was built like a tank. I saw him run over a 4" memosa tree with it and just shredded it. I know memosa's are soft but the thing was bigger than anything I've ever seen anybody run over. It had a 100 hp gearbox that looked as big as the deck. He pulled it with a 70 hp Massey Ferguson. He had his own cane mill and also cut hair, a regular jack-of-all trades.
I don't know what it would cost to build one today, but it could definitely be done. Sorry to ramble.
   / Can one just build a bush hog? #3
Somebody here built one, very tank like.
I'll search, you search and we'll meet back here. ;)
   / Can one just build a bush hog? #4
I see you found it !
On topic ?, oh please. Did you forget where you were ?
haha, yeah, not sure what came over me there! I want a big 8 foot model and I have a welder and a little know-how. I just thought I could build a 2k machine for 500 bucks.
   / Can one just build a bush hog? #6
If you find a source for a angle gearbox let us know. I would think it would need to handle 20hp min or more like 30hp. I can make a deck
   / Can one just build a bush hog? #8
I've got 20GPM but I want a PTO mech drive. I see Agri Supply has a gearbox 40HP for $99.00. Blade RPM would be 800 RPM. Do we want one big blade or 2 or 3 smaller blades?
   / Can one just build a bush hog? #9
Can that JD be fixed up?
If you decide to build one you might want to find a pre-built Stump Jumper and the pins to hold the blade. My "Fred Cane" RC has one big stump jumper, about 24 inch diameter. But I don't think it would be too hard to balance one if you have to make it.
   / Can one just build a bush hog? #10
Wow.. i can't help but think a little bit of dillignece might have saved that mower.. perhaps a slip clutch.. etc.. It's not my opinion that JD mowers are particularly flimsy.
To answer.. yes.. I'm sure you could weld one up... better??? cheaper??? hmm..
Soundguy
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
LIGHT TOWER (A56857)
CATERPILLAR 305 CR EXCAVATOR (A60429)
CATERPILLAR 305 CR...
Unverferth Roadrunner 536 Head Cart (A59814)
Unverferth...
296385 (A57192)
296385 (A57192)
2018 Dodge 5500 Bucket Truck 4WD (A56438)
2018 Dodge 5500...
