Can one just build a bush hog?
   / Can one just build a bush hog? #1
andrewj
Platinum Member
South Carolina
JD 5105
I spent a little much on a JD lx6 that did not last long. almost everything on it is broke due to my abuse, and the hidden stumps/rocks in land I was unfamiliar with.
so, I can't see paying 2 grand for a 7 heavy duty foot cutter. Can I just buy plate steel 7 by 8 or so, brace it, add 3 pt attchment, tail wheel, and gearbox?
Anyone know how much just the deck would cost if made of 1/4 inch steel?
   / Can one just build a bush hog? #2
I saw a homemade one as a child. An older gentleman near my grandparents could build anything.
He had a 6' bushhog that was built like a tank. I saw him run over a 4" memosa tree with it and just shredded it. I know memosa's are soft but the thing was bigger than anything I've ever seen anybody run over. It had a 100 hp gearbox that looked as big as the deck. He pulled it with a 70 hp Massey Ferguson. He had his own cane mill and also cut hair, a regular jack-of-all trades.
I don't know what it would cost to build one today, but it could definitely be done. Sorry to ramble.
   / Can one just build a bush hog? #3
Somebody here built one, very tank like.
I'll search, you search and we'll meet back here. ;)
   / Can one just build a bush hog? #4
I see you found it !
On topic ?, oh please. Did you forget where you were ?
haha, yeah, not sure what came over me there! I want a big 8 foot model and I have a welder and a little know-how. I just thought I could build a 2k machine for 500 bucks.
   / Can one just build a bush hog? #6
If you find a source for a angle gearbox let us know. I would think it would need to handle 20hp min or more like 30hp. I can make a deck
   / Can one just build a bush hog? #8
I've got 20GPM but I want a PTO mech drive. I see Agri Supply has a gearbox 40HP for $99.00. Blade RPM would be 800 RPM. Do we want one big blade or 2 or 3 smaller blades?
   / Can one just build a bush hog? #9
Can that JD be fixed up?
If you decide to build one you might want to find a pre-built Stump Jumper and the pins to hold the blade. My "Fred Cane" RC has one big stump jumper, about 24 inch diameter. But I don't think it would be too hard to balance one if you have to make it.
   / Can one just build a bush hog? #10
Wow.. i can't help but think a little bit of dillignece might have saved that mower.. perhaps a slip clutch.. etc.. It's not my opinion that JD mowers are particularly flimsy.
To answer.. yes.. I'm sure you could weld one up... better??? cheaper??? hmm..
Soundguy
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
2018 Ford F-350 (A55973)
2018 Ford F-350...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
light tower (A56857)
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
