Can two hydraulic cylinders of two different sizes, be plumbed together?
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #1
Bigshooter81
Minnesota
L2501
If they are acting in unison on the same mechanical function or leg?
I have a constraint that only allows for a certain length of retracted cylinder, but at the same time require more of a radial arc than one cylinder can provide on it's own, if I add a linkage, and change the directions of the push/pull, I can add a second cylinder, but am not sure how the function of two potentially different sized hydraulic cylinders will act on the same circuit.
Thanks.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #2
The big cylinder will fully extend before the small one moves because the larger cylinder requires less pressure to lift the same load.
And the same way when retracting?
Otherwise no issues, as long as the meet or exceed pressure ratings?
Will the system be only as strong as the weakest cylinder then I'm guessing?
if they are both the same bore and rod size, but different stroke length will the move in unison until one reaches full extension?
Thanks.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #4
The small one will extend first because it takes a smaller oil volume. If you are trying to use them together like on a loader you will bend something most likely. Retracting force varies with piston size and rod size. It is all based on the square inch displacement, multiply by by psi and you have the force.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #5
Post #2 is correct. If they're both the same size either one could move first, no way to tell without trying it.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #7
How about a sketch of what you are doing, then we could help more.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #8
They will work together, each to their best ability, it they are mechanically forced to, like this diagram of a boom.
If they can operate independently, like this lift platform, they won't lift evenly.
Bruce
Not like a loader. they will be inline with one another, operating a single articulating "dump/curl" mechanism so to speak.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #10
Functioning something like this, mechanically?
Bruce
Bruce
Yes! Thank you for taking the time to provide that..... I am not skilled at drawing, and worse, posting pics.
Thanks.
The function is not for pushing, but for pulling the larger cylinder will have far less leverage, and the smaller more so there shouldn't be any issues with over stressing the cylinders.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #12
Thanks.
Sounds more like this diagram:
Bruce
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #14
Something to consider is to arrange the leverages to not use the cylinders together.
The boom will be hardest to raise when more horizontal. This is when it would be an advantage to use the larger cylinder alone. As the boom reaches, say, 45 degrees, the large cylinder is at the end of the stroke, and then the smaller cylinder continues the lift.
Bruce
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #15
I do not see the need for 2 cylinders in that situation , just tilt that post back and make it rigid. When the angles change so does the leverage. To use them like that you need separate valve control or you have a priority situation where you actually may go down instead of up because of load changes. Backhoes for example have different pressure relief settings for different cylinders because one may over stress another and break a hose or worse.
Bruce
Yes the smaller cylinder will be used with 20 degrees either side of vertical, and the larger from 20 degrees to beyond horizontal.
so hopefully because the bottom of the stroke will be beyond horizontal, and the smaller will have far more leverage, there won't be an issue.
I need 17" of total stroke, but don't have enough room to install a cylinder with that kind of retracted length. Otherwise I would definitely prefer one cylinder. The smaller cylinder will have priority as it will leverage almost 3 time the push/pull poundage as the larger cylinder.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #18
If you don't need down force, maybe a stroke-doubler cable and pulley system would work.
Bruce
Bruce
If I was purely lifting that would work, but the needed movement is a radial curl, and in a very compact area.
   / Can two hydraulic cylinders of two different sizes, be plumbed together? #20
What about when retacting the cylinders? Could the larger one pull the rod or damage the packing of the smaller one?
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
Deere 410L (A53317)
Deere 410L (A53317)
CFG Industrail MX15RX (A53317)
CFG Industrail...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Ram 1500 4x4...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
