Changing form Salt to Potassium in Softener
   / Changing form Salt to Potassium in Softener #1
jeffinsgf
Springfield, MO
JD 4410
I've run my water softener empty of salt and want to switch from salt to potassium chloride. Is there anything I need to know about changing? On my water softener, the label has instructions for every model Westinghouse makes. The one just above mine (of course) has a setting for potassium chloride, but it doesn't say what it changes. Should I worry about that, or just switch and keep on going.
   / Changing form Salt to Potassium in Softener #2
If you don't have a special setting for potassium chloride, just make the change and don't worry too much.
I don't know what it would change insider the softener.
   / Changing form Salt to Potassium in Softener #3
I ran my Waterboss from day one on potassium Chloride. Did not change a thing. I always wandered about changing to salt. Sold it with the house. Need a new one for this house.
Cary:cool:
   / Changing form Salt to Potassium in Softener #4
I use potassium chloride in my softener. Always bought it at Lowes until they decided to price it just below the price of GOLD. It is still $24.95, per 40#. Started out at $7.95.
Checked with the service agency about switching to salt and was told, "No problem."
Have now found another source for potassium chloride at a local grocery store for $14.95 per 40# bag.
By the way, never noticed any difference with the water.
   / Changing form Salt to Potassium in Softener #5
at $14.95 for 40#, isn't that a lot higher than salt?? so whats the advantage of switching from salt?
heehaw
   / Changing form Salt to Potassium in Softener #6
A lot of us geezers have been told to restrict the sodium in our diet. Substituting potassium in your drinking water helps.
Ask your doctor.
   / Changing form Salt to Potassium in Softener #7
You may also want to consider staying with salt, especially if your water is moderately hard. Install a small reverse osmosis system under the sink, for drinking water, and water/ice in the fridge if you have that. These systems run right around $200 at your local toy, oops, I mean hardware store, and remove everything. Some of my clients complain that their water doesn't have ANY taste after installation, and I just add a mineral cartridge in the system to restore that "water" flavor. Really.
lots of good info at budgetwater.com
   / Changing form Salt to Potassium in Softener #8
CurlyDave, Potassium Chloride is a fertilizer so you can run the system flush tube into the grass. And salt is, well you know, salt.
I agree that $14.95 is still higher than salt, but like I said above, I weighed the advantages and disadvantages.
   / Changing form Salt to Potassium in Softener #9
At $10+ per bag savings it would be probably be cheaper in the long run to go with salt and do the RO.
I have installed the top-of-the-line Sears RO in 4 different houses (2 mine, 2 family) and it works great. The filters last about a year and can get a little spendy at $40 for a pair. There are two of them in the system, a pre filter and a post filter. The pre filter is the one that gets 'dirty'. I have taken to moving the post filter to the pre filter position and using just a new filter in the post filter position.... this saves about $20 each time. Since the post filter is filtering water coming out of the RO I am not sure what it is supposed to filter... except $$ out of your wallet :rolleyes:
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A59904)
2016 INTERNATIONAL...
2008 Ford Escape XLS SUV (A59231)
2008 Ford Escape...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2012 Ford E-250 Cargo Van (A59230)
2012 Ford E-250...
