Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,841
My Mobley has yet to test at >6 Mbps down or >2 Mbps up. The local cell tower is two miles away and I can just see the top of it from the window the Mobly hangs in when I'm not on the road with it.
It should do better than that.
Try moving it a little bit and also change the orientation.
When mine was on the window sill moving it a half inch would drastically increase the speed.
And laying flat it was faster with the label side up.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,842
Thanks. I just got some sticky tape. If I can find a better position I might try to weld it in place. Maybe hot glue or something. :sneaky:
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,843
"mjdfhegej ... (ptooey) ... I'm keeping my bait warm, what more does it take to be faster than I can use?"
You could try what I did if you don't want to mess with changing out the mobley itself.
Bought a multiple band booster for about $250 couple years ago/and put the directional antenna on a pole with ability to rotate it. Our Main towers are miles away at the top of a ski resort.
The mobley needs to be placed within about 10 feet of the booster but it made a big difference for us because the mobley was having weak transmit problems 'reaching any of the towers", download was about what xfaxman gets but our upload was in the kbs many days leading to disconnects. Days like today we get like 7 Mbs up
With 4 connected devices right now seeing about 13 Mbs down and 4mbs up. No problem having 2 devices streaming in standard definition and a couple just surfing text sites. The added benefit is some mobile phones also get a boosted signal in the house. Most days if no other devices are on the wlan download speeds are around 25Mbs.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,844
If you have the $20 Mobley plan already, you can keep it.. at least until you screw up and allow a rep to change it. Main reason I *only* deal with reps in a real ATT corporate store and not online or at an 'authorized' store/Best Buy.
My thoughts as well.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,845
This. ^^
We who got in stay in. Buuuut their are newer and similar AT&T wi-fi plans for a few more bucks that do offer something to those without fiber or cable access but decent cel coverage. btw, expect better rates than Verizon as usual. (VZW stockholder, AT&T customer 😁)
Yep. I am on a corporate plan for $50/mo. Plus I have a nighthawk mobile router. When we are at home it is connected to a Yagi antenna. However it has a battery and we could take it with us on the road if we needed/wanted to. Unlimited data. We generally get 20-25 mbs down and 8 up. We don't have children so that is enough of a "pipe" for us. We are on the starlkink wait list, but this plan is pretty good.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,846
How good is your cell phone reception where you live. We have marginal cell service even with a we boost signal booster. I have been wondering if the nighthawk would work
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,847
Anyone still using the plan? The Mobley is not on the ATT list of approved devices anymore. Witht he 3G network shutting down I figgured this would kill this plan. I am not on this plan, but had my MOFI device stop working due to the 3G cut off. My Nighthawk arrives today.
I'm still using it. It's not my main ISP now that I have Starlink, but it makes a great backup. Just did a test and got 81Mb/s. This is with the Netgear Nighthawk M1 modem/router.
As for the original Mobley, it wasn't 3G so even the original device should still work fine if a person has the device and the plan.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,849
Our cell service is fair. Can make and receive calls with no issue. Internet on the phone is like 4mb up or down most of the time. With the nighthawk we have an external antenna that really bosts the reception. If your cell service is marginal with the weboost I would be worried the nighthawk would also be marginal.
Our antenna is not positioned the best either. I suspect if I put it up on the roof we would get even better signal. There was a pole in the ground in a good spot to get the wire into the house. It had a fair line of sight to the cell tower so I just used that spot rather than doing some work to find the ideal spot.
Also the Nighthawk is capable of MIMO so you can put up two antenna offset in opposite directions at 45 degrees to verticle to take advantage of the polarization of the cell signal to get even better reception. We have one antenna oriented vertically.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,850
As posted elsewhere in this thread (IIRC) I bought a weBoost 474120R (Refurbished) back in 2020 for $90. That upped my cell phone reception where I needed it by about 10dB. And worked with the Mobley also.
Is there a screen in the window? Is the glass low-e?
see linky
gravely riding mower (A55758)
gravely riding...
2012 TALBERT 4-AXLE RGN TRAILER (A58214)
2012 TALBERT...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
78in Dual Cylinder...
CATERPILLAR 120M2 MOTORGRADER (A52709)
CATERPILLAR 120M2...
