Circular paver driveway
   / Circular paver driveway
Good find Don. Are you going mix the Claymex bricks in with the Acme bricks.
Yes Ron. I'm waiting for the Claymex to arrive, the mix ratio will be 3 Acme to 1 Claymex. The Brown Claymix are almost a perfect match while the red are a bit brighter than the reds I have.
   / Circular paver driveway #142
Don, I wonder if you could use a "bleach" bath to lighten the red some? Great find though, so now the "tunnel" looks shorter:) End of a prject is in sight!!
   / Circular paver driveway #143
Congrats on sticking with it and finding the pavers!!!
Red is the most famous color for fading. I wouldn't worry about it being a little brighter, it will fade fairly quickly.
Eddie
   / Circular paver driveway #144
Now that you found the pavers, you need Ron to come back and help you finish.;)
Yep, that's the plan. But I need him to stay a week and then give me a month to recupe. I'm just now recovered from the fast paced Ron-get-r-done-work-week. I'm not limping anymore :D:thumbsup:
The pavers weigh 1900 pounds per pallet and I'm getting 6 pallets. I'm using a double axel trailer and a F150. The truck hauling/pulling/trailer weight is 10,000 lbs. The pavers are 100 miles away. Looks like two road trips, and the sad part is that my tractor will not pick up a pallet so I'll have to handle them one extra time.
   / Circular paver driveway #146
Can your tractor pick up half a pallet? Maybe Claymex could put the bricks on twice as many pallets for you. Then maybe you could move them with your tractor. Rick
The pavers are made and bundled in Monterey and they don't make half pallets.
The pavers are stacked and band tied and have thin pieces of wood every 3rd row. On the bottom several rows are left hollow for the forks. So there is no wood pallet that they actually set on. I've contacted a delivery Co. and they will deliver and unload for $575. Still thinking about it....... but for $475 (-$100 gas) it will be like a easy 2 day job.
   / Circular paver driveway #148
When you get to be my age. You will know better than to do the 3 miles run after a full day of work. It was enough for me to follow you in the golf cart. :D
Wisdom comes with age. Limitations are sneaking up on me.:eek:
Later this week the next section will open. I'm dragging because of the heat and several other obstacles. My cousin sent me the following e-mail of a PARTY ON THE PAVERS. It enthused me to get a move on it!
"What a crazy, delightful ever changing world! Who could have thought that in 2012 young people in Moscow would put on a "flash mob" happening, dancing to an 83 year old American song written by a Russian born American Jew (Irving Berlin)? "
Цекало и Puttin` отожгли на Воробьевых горах - YouTube
section 5 reject tree.jpgsec 5 reject.jpgI finished section 5 and 5.5 yesterday and had to cover it up because of the rain. The rain turned out to be less than 1/8 inch. The tarps came off today and I am happy with the results. section 5 was the largest section so far with 1600 pavers and section 5.5 has 350 pavers.
This section was the first section that combined both the American and the Mexican brick. It had it's challenges since the Mexican brick were bigger by 1/8" and because of the summer heat and occasional storm.
Pictured below I had to start over after the grout lines did not line up because of the accumulation of that 1/8". I figured out that I could NOT do random but alternating lines of Mexican and American pavers.
Here are the pictures after I figured it out and got it together. Section 5 and 5.5 required hundreds of cuts because of the shapes and the different size pavers. The Harbor Freight 10" wet circular brick and tile saw with the continuous diamond blade worked flawlessly, and I'm still on that first $29 blade!
Section 6 is shaped as a Y and will require the most pavers. It will be the last section. YEA! I will attempt to put a compass rose in the middle of the Y. I am taking the week off to re-group. I also need to make another paver run. A % of the Mexican Pavers were cracked (I caught them before I laid them). The company is standing behind their product and replacing the defective pavers.
   / Circular paver driveway #155
Don, very nice job! Not what I had pictured in my mind - 10,000 times better! You have to be very proud of that project.:thumbsup:
   / Circular paver driveway #157
That looks really good!:cool: I was proud when i laid about 800 to make my front walk!:D
Thanks guys. Here is a picture Feb 2011 two months before my heart attack. (Yes that is the one day of snow we got in Texas.) The outer curbing had just been poured (bag by bag- one bag per foot) All the pavers laid are during my recovery. The hottest day so far was last Tuesday at 106 degrees, and yes Ron I did manage to complete my 3 mile heart run that evening in 30 minutes only to get a call from my wife of a 2" water leak in the blackland and was shoveling in knee high mud till midnight........ I feel recovered! :thumbsup:
   / Circular paver driveway #159
Drive looks very nice. Did you add a new piece of equipment for cutting pavers? If you still have pavers to lay next April. I will be glad to help. I will follow you in the Golf Cart for your 3 mile run though. The way Betty's knee is healing she may do the run with you. :D
   / Circular paver driveway #160
Way too pretty to DRIVE on!
Can you imagine a glob of grease or God forbid an OIL LEAK!
Don that is awesome sir!
Want to come make me a little patio for my outdoor kitchen project? I'll feed you...
David
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
