Cleaning Snow From Blower; Tell Me How
   / Cleaning Snow From Blower; Tell Me How #11
   / Cleaning Snow From Blower; Tell Me How #13
A kerosene fired salamader works wonders also I have had mine for 16 years now and its been a godsend for the trucks, firewood processor, ice jams in down spouts.....
Every now and then you can find a nice deal on propane fired salamanders also. I picked one up at a local Big Lots for around $50. You can either use a gas grill tank or purchase a larger tank for it.
   / Cleaning Snow From Blower; Tell Me How #14
The one thing my snowblower can't handle is when the weather turns warmer and creates an 1-2" wet layer of snow on top of the cold snow below. That stuff instantly freezes to the auger and the housing. Never caused a clogged chute tho. May be if your garage is heated and as the warm snowblower digs into the snow it creates a layer of ice then the snow sticks to that very well? My garage is not heated so I don't have that problem. As for clean up I just use an old broken broom without the handle. It works pretty well. I NEVER clean that thing with the tractor running. NEVER.
   / Cleaning Snow From Blower; Tell Me How #15
I don't have a blower , but my plow does the same thing if I take it out of the garage and start using it right away. The plow is warmer than the snow and when the snow gets on the plow it melts a little and then freezes to the plow and frame. I have found that if I let the tractor sit out side for about 15 min. before I start plowing I don't have the problem.
Bill
   / Cleaning Snow From Blower; Tell Me How #16
I use the simple approach to snow removal on the blower, I do not worry about it. I have grease fittings on the chute rotator that gets a shot at the start of the season and the chain gets a heavy spray of industrial wire rope lube. I keep a D handle shovel no snovel head behind the seat for pocking out the chute. The machine is stored in a unheated building and I have never had a snow linger on the blower when SPRING arrrives.
Craig Clayton
   / Cleaning Snow From Blower; Tell Me How #17
I use a couple of those short handled plastic windshield scraper/brushes. One w/scraper for cleaning out the blower/auger area and the second one without scraper for brushing the snow off everything else. Works pretty good for me. I have a heated garage and the floor drain can only take so much water in the winter without loading up. Machine is always turned off when doing this.
   / Cleaning Snow From Blower; Tell Me How #20
I have a different problem. When I pull it into the heated garage (45-50 deg) the **** snow melts and flows towards the garage door and makes a mess :)
2017 Jeep Patriot 4x4 SUV (A55758)
2017 Jeep Patriot...
Ford 670 (A53314)
Ford 670 (A53314)
CAT CB-54XW (A53314)
2007 Walker PDT3A 3inch Diaphragm Pump (A55787)
2007 Walker PDT3A...
2021 WESTERN STAR 4700 DUMP TRUCK (A55745)
2021 WESTERN STAR...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
