OP
ns_in_tex
Platinum Member
- Joined
- Mar 24, 2002
- Messages
- 924
- Location
- East Texas
- Tractor
- Kubota L4610 HSTC, International 2400, Hesston 1280,
Rozett
Your are right about the rear lift capacity being greater. My original plans were to build it to work on front or rear & on a larger tractor. It was more than twice as tall (for top link connection). When I got to the point I could try it out on the fel, I found that in this soft sand I had to go down in the ground a little to get enough pressure behind the tree to make the teeth cut into & hold well. If there was a tree I wanted to save, very close behind the one to remove, the top of my implement (when set at a 45 deg tilt to go down) would scar the bark on the other tree. Also I think the one on the fel will be much eaiser to use facing forward & eaiser to slide the hung tree back out of the teeth when unloading. This is when I made the decision to cut the top of the implement off & have two separate implements. Do all I can with the fel, then what I can with the rear attachement & what that won't do, I will have to use the chain saw.
Neal
Neal
