come alongs
/ come alongs #23
Any recommendation on the ‘blue rope’?
Never used the blue rope, only the cable. As much as I use it, winching a log any distance is not one of the reason that I would use it for.
Having a long cable attached to a vehicle (4x4) and the log to drag out, is the way to go. Might have to lay a log or two over the edge. :2cents:
/ come alongs #24
Winching anything a long distance is not my ideal use for a come along.
/ come alongs #25
I'd second the idea of hanging a snatch block in a tree just high enough so that you get a straight pull from the fallen log to the snatch block with some elevation so as to lift the log up a bit as its pulled to keep it from digging in. You can even use multiple blocks to keep the cable off the ground and finally to a vehicle to provide pulling power.
Repositioning the cables and snatch blocks, and tow vehicle multiple times will still be way less work than cranking the lever on a come along or hand winch.
The few times I've done it, I was pleasantly surprised how well it went with my Suburban, one snatch block, and a 100' cable.
/ come alongs #27
I kept myself in firewood for years with a Jeep, 100ft of 3/8 cable, and a couple of 50ft ones. Had a couple of snatch blocks, too.
Bruce
/ come alongs
thanks for all the good suggestions. looks like cable snatch block and pickup will work out best. i'm glad i posted this thread here.
/ come alongs #29
When pulling the logs, stay in first gear and ease into it....
/ come alongs #30
i have some fairly large logs on the ground on a downhill slope. the slope is steep. i want to pull them up to where i can cut them and use them for firewood. i have no tractor here to work with. so will a come along do this? any come along recommendations?
Where are the pictures? Haven't read the whole thing yet so maybe in here later.
Ron
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
2008 Ford E-450 Super Duty Ambulance (A64556)
2008 Ford E-450...
2020 CATERPILLAR 299D3 SKID STEER (A65053)
2020 CATERPILLAR...
2020 Bobcat S450 Compact Wheel Loader Skid Steer (A64553)
2020 Bobcat S450...
Winchester Sign (A64557)
Winchester Sign...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
