come alongs
/ come alongs #23
Any recommendation on the ‘blue rope’?
Never used the blue rope, only the cable. As much as I use it, winching a log any distance is not one of the reason that I would use it for.
Having a long cable attached to a vehicle (4x4) and the log to drag out, is the way to go. Might have to lay a log or two over the edge. :2cents:
/ come alongs #24
Winching anything a long distance is not my ideal use for a come along.
/ come alongs #25
I'd second the idea of hanging a snatch block in a tree just high enough so that you get a straight pull from the fallen log to the snatch block with some elevation so as to lift the log up a bit as its pulled to keep it from digging in. You can even use multiple blocks to keep the cable off the ground and finally to a vehicle to provide pulling power.
Repositioning the cables and snatch blocks, and tow vehicle multiple times will still be way less work than cranking the lever on a come along or hand winch.
The few times I've done it, I was pleasantly surprised how well it went with my Suburban, one snatch block, and a 100' cable.
/ come alongs #27
I kept myself in firewood for years with a Jeep, 100ft of 3/8 cable, and a couple of 50ft ones. Had a couple of snatch blocks, too.
Bruce
/ come alongs
thanks for all the good suggestions. looks like cable snatch block and pickup will work out best. i'm glad i posted this thread here.
/ come alongs #29
When pulling the logs, stay in first gear and ease into it....
/ come alongs #30
i have some fairly large logs on the ground on a downhill slope. the slope is steep. i want to pull them up to where i can cut them and use them for firewood. i have no tractor here to work with. so will a come along do this? any come along recommendations?
Where are the pictures? Haven't read the whole thing yet so maybe in here later.
Ron
Wooden Glider Chair (A64557)
Wooden Glider...
2019 Chevrolet Tahoe (A64194)
2019 Chevrolet...
Heavy-Duty Round Livestock Bale Feeder w/ Hay Saver (A66408)
Heavy-Duty Round...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
