Confused About HST Fan Protection
   / Confused About HST Fan Protection #42
Thanks for the input on the overheating issue. I know there is no way to know the exact HST temp, I was just looking for a seat of the pants/educated guess type of thing. I guess if it can run without a fan, the skid plate probably doesn't hurt.
Matt.
I'm still a little concerned about this. When I mow with the bush hog, grass piles up on top of the drawbar. With the Bro-Tek on, it gets trapped there and really packs in against the transmission. This seems like it would provide good insulation preventing much heat from radiating.
On the other hand, I think the skid plate makes contact with the bottom of the transmission. If that's the case, maybe it helps to conduct some heat away from it.
   / Confused About HST Fan Protection #43
I went to my dealer with pictures from this thread of both the old and the newer Kubota Guards. We were only able to find a part call out for the older -smaller guard and not the larger new guard. When somebody can get a part number, please post it.
Just a bump. I would be intrested in getting the New Kubota guard that the OP posted. This is quite compact and modifyable. Good ventilation. Easy shaft hook-up. Could be easly modified in the front for additional protection.
Is anybudy else intrested? Any luck getting a part number? Let me know and I will get the guard and modify than provide pix.
   / Confused About HST Fan Protection #44
I looked at a new BX2360 or 2660 on the lot yesterday, and it didn't have a guard of any kind on it. I'm not sure how long it had been sitting on the lot though.
   / Confused About HST Fan Protection #45
Would be nice if the OP would ask his dealer where the guard came from. I would bet that the dealer put it on himself but who knows until we find out the true story.
thavil, np
I personally still contend that this is a mid-build change. Auto makers do this kind of stuff all the time.
Kubota is not the fastest outfit in updating things electronic, as in manuals, pdf files, lists, website, etc. Not a super criticism, just an observation.
   / Confused About HST Fan Protection #49
OK, here a photo of my underneath 'Bota.
Sorry the photo is what it is, but you can see the part anyhow.
Guess what fellows, just got my new 2009 BX 2660 today and it has the same HST guard as pictured by bp fick. I'm relatively sure the dealer didn't put it on, because we never talked about it.
Looks like they are putting these on the new machines.
   / Confused About HST Fan Protection #50
thavil, np
I bought my BX2660 in July and it came equipped with the latest version of the hst fan protector. I use it in the woods regularly and have not had any trouble, though I do check it regularly. Believe me, it is not a dealer add on...this is definitely a factory upgrade. I have tried to find a part number to pass along, but no luck. I do think whatever you fabricate to protect the fan should have good air flow. Over time, heat will break down hydraulic fluid and effect the performance of the entire hydraulic system. Some of the skid plates pictured in previous posts look like trouble to me, completely blocking air flow and holding heat in rather than dispersing it. That could be easily remedied by cutting thin slots or drilling small holes in the plate to improve air flow.
Well, well, well!!!!!! That now makes THREE posters who have recently purchased BX's with the new HST fan guard. That, my friends, is proof that my suspicions were right. This is indeed a mid course correction by Kubota. How 'bout that! It sounds as if it is long over due, but anyhow...
   / Confused About HST Fan Protection #52
Any new leads on the new part number?
   / Confused About HST Fan Protection #55
I want 1 or 2 of them.
   / Confused About HST Fan Protection #56
I is.
   / Confused About HST Fan Protection #57
I sure would be interested; getting about time to pull the MMM off for the winter.
Since it is been asked again, : It is indeed bolted on. Not welded on.
This will be a great, easy to install, (remove rear tires, I suspect) upgrade. Sorry guys, I have had no luck in establishing part number, but that is going to turn up soon, because Kubota has installed this, apparently, on all units manufactured in the last 4 months. I smiled as I drove across field today to pick up my neighbor's rake.:D
   / Confused About HST Fan Protection #59
Got a response today direct from Kubota
There was a change in the fan guard, there is a Serial Number break, the
new fan guard is slightly larger and will fit the older machines. There is
no provision to provide this for free, you can purchase it from your
dealer.
Part number for the new guard is K2681-21212
Kubota Customer Service
As stated, it would be soon!! LOL :D:D:D:D
Order away boys!!!! Maybe Messicks can get a dozen for all the people here.
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2364 (A60432)
2364 (A60432)
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
4ft Mini Skid Quick Attach Rotary Cutter (A61306)
4ft Mini Skid...
