Creating a Workshop & Home
/ Creating a Workshop & Home
Most panals I can get on the wall easy enough by sliding them up my ladder until I can rest it on the one below.
For the ones above the roll up door opening, I couldn't do that. The ladder has to rest agains the wall, and the panal needs to be inbetween the wall and the only place the ladder has to rest.
My solution was to use my tractor.
The top of the door opening is 10ft.
I screwed on a piece of plywood to the opeing to provide a rest for the panal while lining it up, and to help hold it in position while nailing.
Sometimes working alone has it's drawbacks. /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/grin.gif
This gives you an idea of how it's gonna look when finished.
Eddie
/ Creating a Workshop & Home #203
Eddie,
I have been following your posts for quite a while and I do not recall your mentioning insulation. Do you have a plan on the insulation? Not to sure how expensive it is but quite a few people in Michigan use the commercial sprayed on foam and it works great. They get approximately 1 inch of foam. It seals the building, looks great when finished and has a good R factor as well.
Insulation, along with sheetrock, doors and windows will be coming in next week.
I'm going to uses regular R30 bats in the ceilings and R13 in the walls. Nothing fancy, just the cheapest and most common type available.
My goal is to have the siding on this weekend and to have the electircal and plumbing rough in done next week. Sheetrock is to be finished with texture by months end.
/ Creating a Workshop & Home #205
I am seeing more Polyurethane foam spray-on insulation around here too. Mostly used in conjunction with metal roofing on timberframe and log homes. Supposedly, when applied directly to the underside of the roof, it virtually eliminates condensation problems.
/ Creating a Workshop & Home #206
Stop the presses, working ALONE, where is super woman and the kids who are getting a better education with you than they can in schools. Please dont tell us bad news.
BTW, the building is looking great!
/ Creating a Workshop & Home #207
In the next year or so I am going to explore the cost to have the spray foam sprayed on the ceiling of an industrial fiberglass panel lean-to that I am going to use for my welding shop. The panels sweat quite a bit leaving rust spots on my metal stock. I could use the foam sheets but think the spray will work better in this situation. If I find that it is comparable in cost to other insulation, I have several other areas I am going to have foamed.
Sorry Danny, heres a shot of "super woman" hanging the house wrap on the second story.
It was only 90 degrees today with the humidity at 60%, wich is really mild. Even so, it was much hotter on the roof, and she really suffered. But she doesn't quit until its done!!!!
She really is my "super woman!"
Eddie
/ Creating a Workshop & Home #210
Thanks Eddie,
there for a second in the post I replied to, I thought she had hung up the tool belt on you........you said working alone! I can not see you doing something on this and the gf not being in it.
You have a winner there, and thanks for the photos.
/ Creating a Workshop & Home #211
Eddie-
Quick question(s): Metal roofs are fairly common up here in the NW. Are they also common in your area with the weather being as it is? Does it heat the place up any more than a comp roof or does metal reflect the heat?
I know it might sound like I am kissing up, but you are one macho guy with a macho girlfriend! Your work (and documentation thereof) are very inspiring.
Keep cool,
Bonehead
Bonehead,
I don't know how much a diference a metal roof makes compared to composite ones underneath. Both are almost more then I can take during the heat of the day. The metal one is much, much hotter to be on during the day!!!
I was told the silver and lighter colors reflect the heat, but my container barn has a silver roof, and if it's reflecting any heat, I don't believe it.
As for being common, they are getting there. We have an aweful lot of metal building around here, and I'm seeing more and more custom homes being build with metal roofs. Even in the exclusive gated communities.
I like them mostly for there apperance. It's just something I like.
Eddie
/ Creating a Workshop & Home #213
You're right. Not connected to building roofs, but I have some experience with cars. White car has much lower roof temperature then silver painted car.
This is what I have to deal with. Heights are a fear of mine, and the higher I get, the greater my fear!!!!!!!!!!
I've been looing at this, trying to figure out how to aproach it, but mostly stalling, trying to build up my nerve.
/ Creating a Workshop & Home #215
I might suggest scaffolding, the cost of renting or buying sure beats a fall from that height. Plus think of the view from up there!
Turns out my buckets maximum height is just above the upstairs window sill. All I had to do was park the tractor at the window, climb out the window, and work away. /forums/images/graemlins/smile.gif /forums/images/graemlins/frown.gif
At first I was pretty nervous, but fairly quickly, I gained confidence and was able to bring a stool out to stand on inside the bucket. Gave me another 16 inches of reach!!
I'll have to get the very tops from above, but with the rain we got today, there's no way I can stay on a slippery metal roof. Can somebody say "waterslide." /forums/images/graemlins/shocked.gif
Eddie
/ Creating a Workshop & Home #217
How did I know the tractor would come to the rescue. Looks good!
/ Creating a Workshop & Home #218
Break out the ropes. The open upstairs windows give you the ability to tie off the upper end of the ladder to interior framing. The bottom can be secured by staking. Not sure if you're using multiple ladders with walkboards or moving a single ladder as needed, but either will work. Alternately moving and securing a single ladder is less convenient, but very worthwhile. It's also a whole lot better than being 30 feet off the ground wondering if your ladder is going to kick out and wondering why in blazes didn't I take the five extra minutes to secure this thing properly. Knowing for absolute certain that the ladder is going to stay under you does a whole lot to reduce fear of heights.
As a professional firefighter assigned to a ladder truck, I get used to throwing ground ladders under less than ideal conditions (assuming you consider the house the ladder is against being on fire to be less than ideal /forums/images/graemlins/grin.gif). Accordingly, I've always said it's not heights that make me nervous, it's heights when I'm not sure I'm going to stay there. Somehow, that's still not a reassuring thought when stepping off the edge to rappel down a 12 story office building. When I'm working off my own ladders on my own time, I make very certain I'm comfortable with the way my ladder is set and secured. It's not worth risking my hide and my livelyhood to save a few minutes of proper setup.
Set it up right, knock it out and relax with a beverage of choice. Few feelings are better than seeing a difficult job you didn't want to do done, and done well.
/ Creating a Workshop & Home #219
OK, I think you were a bit faster than me on that last post. /forums/images/graemlins/blush.gif Good to see the job done.
Danny,
My first thought was to get the dump truck and put the ladder in the back. But the battery is dead, so instead of jump starting it, I noticed my tractor sitting there and wondered how hi I could get the bucket, and how I'd get into the bucket once it's up there.
Hurricane THB750 Hydraulic Breaker Excavator Attachment (A61572)
Hurricane THB750...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
UNUSED WOLVERINE 60" HYD DRUM MULCHER (A64281)
UNUSED WOLVERINE...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
