Cultipacker wood bushing replacements
   / Cultipacker wood bushing replacements #1
dhayse32
I just got an old 2 row 8' culitpacker off of a buddy. It is a Vulcan brand, made in Evansville, IN back I would guess 40 years or so. The front row of packers needs to be tighten, but works great. The back row comes off with ease and rolls, however the wood bushing on it need to be replaced. Any one know where to get these or have them made? No one in my area makes these or has access too. Thanks
   / Cultipacker wood bushing replacements #2
I know there are flats inside the cast housing, however, most people take a piece of wood stock and turn it to a outside diameter that can be driven in there. Bore the hole thru the center for the axle, (usually 1 3/4 inch for the Vulcans). The fast way to keep it in the field is to drive wood slivers around the axle and housing to take out the slack. Ken Sweet
Thanks alot Ken. What type of wood would you recommend?
   / Cultipacker wood bushing replacements #4
Oak, Hickory,Ash. Even pine would wear many years with proper lube. We have intentions to start making these when the spring rush is over. We have a fellow that works for us that has a wood Lathe at home. Ken Sweet
   / Cultipacker wood bushing replacements #5
dhayse32, I found this old thread moments ago. How did replacement of that wooden bushing on your Vulcan cultipacker ever go? I just bought one yesterday that needs bushings and probably more.
I would appreciate it if you would PM me and give me the benefit of your experience.
Thanks.
   / Cultipacker wood bushing replacements #6
We have a few made from red cedar for $12 each. Ken Sweet
   / Cultipacker wood bushing replacements #8
He hasn't posted since May 2010.
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
Case-IH 370 Steiger (A57148)
Case-IH 370...
2018 Ford F-350 (A55973)
2018 Ford F-350...
TANK MANIFOLD (A58214)
2001 International 4000 DT 466E (A60462)
2001 International...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
