Cutting a log lengthwise for a fireplace mantle
   / Cutting a log lengthwise for a fireplace mantle #11
General rule for airing drying is 1" thickness per year. Could you a swap - take the log to a local mill to cut or swap materials for a live edge pieces that they may have. Does she want a live edge on it or just squared up?
   / Cutting a log lengthwise for a fireplace mantle #13
I just finished a mantle for my parents fireplace that was a cedar tree from the land. It had been down for a couple of years and had a really nice shape to it. I wanted it to be 5 1/2 feet long with a flat top and back. The front and bottom where to remain natural in shape, but highly sanded.
To cut it, I used a chalk line to have something to follow. I put the log in a pair X shaped saw horses that I made from scrap 2x4's at an easy to cut height. First I cut it shallow with the chainsaw to get my line. Then I cut it all the way, taking my time to make sure I kept the blade straight down. Then I rotated the log 90 degrees, put down another chalk line, cut it shallow, then cut it all the way.
The log was about a foot longer then I wanted it, so after cutting the length, I cut it down to the exact length that I wanted it to be.
Then I sanded it with my big belt sander and used a six foot level as a straight edge to find my high and low spots. With 40 grit paper, it got it all leveled and smoothed out in a couple of hours.
302.jpg 304.jpg 306.jpg 308.jpg 312.jpg 1533932_10203034793173453_1046388994_n.jpg
Eddie
   / Cutting a log lengthwise for a fireplace mantle #14
I used my Alaskan mill to do a mantle for my neighbor. No pix, had to build a custom mill head (not so custom but it works) to do the verticle cut. A ripping chain is very nice to have in the process. Downside is that a big piece of wood needs years to properly dry.
These are some pictures of maple and cedar I cut up.... Making property benches (benches along hiking trails)
   / Cutting a log lengthwise for a fireplace mantle #15
I have a Beam Machine that worked well for cutting timbers for an outdoor bench.
E slower
http://www.beammachine.com/
The Beam Machine is the way to go. Just use your regular chain for a one time effort. It will just be a little slower.
Or: screw a 2x4 onto the log as you have stated. Then bolt a piece of wood/steel at 90 degrees to the bar and use that for alinement. You'll have to drill a hole in the bar but that is not a big deal.:thumbsup:
Cut the piece at least a foot and a half longer than required.
An electric hand planer would work well for finishing it off just prior to sanding.
   / Cutting a log lengthwise for a fireplace mantle #17
I have a Granberg Alaskan Chainsaw Mill, as well as their Mini Mill (which is cheaper and the only thing you need for sawing beams or a piece like this mantle). However, I use a 77cc chainsaw, because that is what's required for milling (and many people go even bigger). I also use rip chains. You will most likely melt down your little Husky if you attempt to use that saw for such a long (time wise) set of cuts. It will not cool quickly enough, and it's not a pro saw that can handle repeated long cuts.
As far as drying, do not expect quick results if you want to do it right. A piece like that is going to need to air dry for a few years. The only way to accelerate it without wrecking the wood is to find someone with a kiln who knows how to use it.
Not trying to rain on your parade here, but you're heading in a direction that will trash your saw and leave you with a big warped piece of green wood.
Thanks everyone............what Eddie Walker is describing is the look I am going for. So I think I will try to get the full log out of the bush (with my snowmachine maybe with a sled drag) and then use chalkline or 2 x 4 strapped to it like Eddie and others described.
The drying part will be the tricky part, I have finished other rustic furniture (like bar stools) before that was only cut green 3 months before and it still looks great. I am not worried so much about checking,(that just adds to the rustic flavour) I just want varnish finish to stay on it.
here is pic of bar stools that I need mantle to match
   / Cutting a log lengthwise for a fireplace mantle #19
You could make up a frame to cover the log, drape some plastic over it, then provide a little heat and ventilation to dry it out faster. A 100 watt light bulb and a small muffin fan would greatly speed the process up. Just remember to do like has been suggested and seal the ends. Even this method will take quite a bit of time to dry out to a workable moisture content, but a lot faster than just air drying.
   / Cutting a log lengthwise for a fireplace mantle #20
Load it on a trailer and take it to a local saw mill. That's what I would do.
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
