Deck over trailer for tractors
   / Deck over trailer for tractors #22
Many pieces of equipment and tractors will not fit a fendered trailer.
And you for sure need to measure the overall load height.
   / Deck over trailer for tractors #23
I understand what your saying about either direction. Could you temporarily turn in the top link on 3pt just for loading? This would give more clearance right? B
I have TnT, so raise the back edge of the impliment every time without even thinking about it. I'm sure that's why the angles on my tilting deckover are less problematic than you'd expect, now that I think about it.
The mini backhoe I posted earlier scraped ever so slightly on a level load & unload. But again, not enough to wory about.
   / Deck over trailer for tractors #24
Generally the width between fenders is 81-83" or so. Max width is 102", minus 2 tires, a little clearance & fenders.
   / Deck over trailer for tractors #25
Deckover trailers are far more versatile and capable once any unnecessary fears about load height are overcome.
"Fears" are not a factor.
Physics is!
   / Deck over trailer for tractors #26
Physics is!
Bumper pull campers are bar none the worst designed and pulling trailers on the road. The higher GOG of a deck over trailer is an unfounded fear. Do you see them just rolling over? As to load height until you get into construction equipment and massive tractors it’s a non existent concern.
   / Deck over trailer for tractors #28
Physics is!
And yet a semi trailer weighs over 40,000 lb loaded and the deck starts over four feet off the ground...
If it is a box trailer, there is often significant weight all the way up to 13 ft off the ground.
Aaron Z
   / Deck over trailer for tractors #30
That 3’ dovetail looks pretty steep but maybe it’s fine. Why not just demo the trailer and drive up it?
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
LOLOT OF ROUND STOCK 2PC. (A58374)
LOLOT OF ROUND...
